Rationalize the denominator: ##\sqrt{\dfrac{1}{2x^3y^5}}##
  • Thread starter Thread starter RChristenk
    algebra-precalculus
The discussion revolves around the rationalization of the denominator for the expression √(1/(2x³y⁵)). The initial steps show the transformation to a form involving absolute values, specifically |x| and |y|, to ensure positivity. However, the book's solution omits these absolute values, leading to confusion about the positivity of the final result. Participants clarify that while x and y could be negative, the original expression is always defined as positive due to the square root operation. Ultimately, the conclusion is that the original fraction remains positive when properly defined.
RChristenk
Operations involving radicals
##\sqrt{\dfrac{1}{2x^3y^5}}=\dfrac{1}{\sqrt{2\cdot x^2 \cdot x \cdot y^2 \cdot y^2 \cdot y}}=\dfrac{1}{|x|\cdot |y|\cdot |y| \cdot \sqrt{2xy}}=\dfrac{1}{|x|y^2\sqrt{2xy}}##
##\Rightarrow \dfrac{1}{|x|y^2\sqrt{2xy}} \cdot \dfrac{\sqrt{2xy}}{\sqrt{2xy}}=\dfrac{\sqrt{2xy}}{|x|y^2 \cdot 2xy}=\dfrac{\sqrt{2xy}}{2|x|xy^3}##
But the solution is given as ##\sqrt{\dfrac{1}{2x^3y^5}}=\dfrac{1}{xy^2\sqrt{2xy}}\cdot \dfrac{\sqrt{2xy}}{\sqrt{2xy}}=\dfrac{\sqrt{2xy}}{2x^2y^3}## without any consideration for the absolute value. But the definition is ##\sqrt{x^2}=|x|##, so I'm not understanding why the book solution ignores this.
The original expression is positive, so there is no way to end up with negative values. If so, then it should be ##|y^3|##.
Likes FactChecker
Are there assumptions in the problem that you don't show? IOW, are the variables x and y assumed to be nonnegative?
Nope. But if ##x,y## can be negative, would this be correct: ##\dfrac{1}{|x||y^2|\sqrt{2xy}}\cdot \dfrac{\sqrt{2xy}}{\sqrt{2xy}}=\dfrac{\sqrt{2xy}}{2x|x||y^2|y}##.
Is there a way to simplify ##2x|x||y^2|y##?
No, because your final answer would be negative if exactly one of x or y were negative. The original fraction is always positive.
That denominator should be ##2 x^2 |y^3|##, which is always positive.
Why is the original fraction always positive? I'm confused because by definition ##\sqrt{x^2}=|x|##. So ##x## itself could be a negative number.
Hence in ##\sqrt{\dfrac{1}{2x^3y^5}}##, ##x,y## could be negative and since it's to the third and fifth power respectively, stay negative. Thanks.
I'm sorry. I misstated. ##\sqrt {\frac {1}{2x^3y^5}}## should always be positive, when it is defined. (I am assuming that your class does not deal with complex roots of negative numbers.) That is how the ##\sqrt {\ \ \ }## symbol is defined.
  • · Replies 17 ·
