Rationalizing this fraction involving square roots
The discussion revolves around simplifying the fraction involving square roots, specifically the expression (√5 + √3)(√5 + √2) / (√5 + √3 + √2). One participant describes using brute force by multiplying the numerator and denominator by (√5 + √3 - √2) to rationalize the denominator. Another contributor suggests that this method may be cumbersome and proposes an alternative approach involving algebraic manipulation. Ultimately, the conversation highlights the complexity of rationalizing such expressions while seeking more efficient methods. The participants appreciate the insights shared during the discussion.
songoku
Simplify:
$$\frac{\left( \sqrt{5}+\sqrt{3} \right) \left(\sqrt{5} + \sqrt{2} \right)}{\sqrt{5} + \sqrt{3} + \sqrt{2}}$$
Rationalization
I can do the question using brute force. First I multiply both the numerator and denominator by ##\sqrt{5} + \sqrt{3} - \sqrt{2}## then I simplify everything and rationalize again until no more square root in the denominator.
I want to ask if there is a trick to reduce the monstrous calculation
Thanks
songoku said:
Homework Statement:: Simplify:
Relevant Equations:: Rationalization
Thanks
I believe you are stuck with that method. The alternate is probably even worse:
##( \sqrt{5} + \sqrt{3} + \sqrt{2} ) ( - \sqrt{5} + \sqrt{3} + \sqrt{2} ) ( \sqrt{5} - \sqrt{3} + \sqrt{2} ) ( \sqrt{5} + \sqrt{3} - \sqrt{2} ) = 24##
-Dan
Likes songoku and PeroK
If ##c = a - b##, then:
$$(\sqrt a + \sqrt b+ \sqrt c)^2 = 2(a + \sqrt{ab} + (\sqrt a + \sqrt b)\sqrt c) =2(\sqrt a + \sqrt b)(\sqrt a + \sqrt c)$$Hence:
$$\frac{(\sqrt a + \sqrt b)(\sqrt a + \sqrt c)}{\sqrt a + \sqrt b+ \sqrt c} = \frac{\sqrt a + \sqrt b+ \sqrt c}{2}$$
  • Wow
Likes songoku, Steve4Physics and topsquark
Thank you very much for the help and explanation topsquark, PeroK
