[Ray Tracing] Wavefronts & Reception Sphere
In summary, the wavefront is a plane wave that is normal to the ray and has an area defined by the ray tube (which expands due to dispersion as the ray travels). Rays are received if they lie within the wavefront. The double count problem is when parts of the wavefront overlap.
whitenight541
49
Hi all,
I'm confused about the concept of wavefronts in ray tracing .. each ray is considered a wavefront? or what exactly is a wavefront in ray tracing?
In the reception sphere, it is mentioned that only one ray should be received from an actual path. I don't get it .. does this mean that if a ray is received then after some tracing the ray is reflected and reached the receiver again it shouldn't contribute again to the total power received?
Some papers also describe the double count problem. I don't understand what this problem is about .. I think it has something to do with wavefronts (which I'm confused about)
thanks in advance
I'm a little confused by your terms- I don't know what a 'reception sphere' is.
In geometrical optics, the rays are normal to the wavefront, but the wavefront is usually not something to consider in geometrical optics. Aberrations are treated differently in ray optics vs. wave optics.
Each ray represents a "local" plane wave. The wave front is simply a plane wave that is normal to the ray and has an area defined by the ray tube (which expands due to dispersion as the ray travels).
I am not sure about what this reception sphere is or about how you expect a ray to contribute to the total power. If I recall correctly, no ray is used for the observeables. The rays are used to find the excited surface currents on your scatterer. Then, you take the currents and integrate them with the Dyadic Green's function to find the scattered fields. The direct field is a separate problem, which I guess you could use a "ray" to figure out as well but really you define the excitation in the beginning, this is known and so the direct field is a separate and easier problem.
I can't remember what double counting is, I read about in the documentation but I can't remember what it is.
The reception sphere is a technique to determine with rays are actually received by a receiver. It constructs a sphere around the receiver with radius proportional to the angular separation between rays and the total unfolded distance traveled by the ray. If the ray lies within the sphere then it is received and it contributes to the total field at that receiver.
I think I understood the double count problem:
Apart from ray tracing, we can imagine the waves emitted from the source as spherical waves increasing in size as they move away from the source. The wavefront is spherical in that case. If we divide the wavefront (at distance r) which is a sphere using hexagons, I think each of these hexagon would represent the wavefront of a ray. Each ray has a well defined non-overlapping wavefront with the neighboring rays.
If we return to the reception sphere concept, we construct the sphere about the receiver and say that the ray is received if the ray lies within that sphere. We can reverse things a little bit and say that the ray is received if the receiver lies within the wavefront of the ray. The wave front is hexagonal while the reception sphere is obviously spherical. The hexagonal shape is approximated by a sphere and that causes the double count problem (since now parts of the wavefronts overlap)
Does this make any sense? :D
FAQ: [Ray Tracing] Wavefronts & Reception Sphere
What is ray tracing?
Ray tracing is a rendering technique used in computer graphics to create realistic images by tracing the path of light as it interacts with objects in a scene. It simulates the behavior of light, including reflection, refraction, and absorption, to accurately depict how it would appear to the human eye.
What are wavefronts in ray tracing?
Wavefronts refer to the imaginary surfaces that represent the advancing front of a light wave as it travels through a scene in ray tracing. These wavefronts are used to determine the direction and intensity of light at each point in the scene, allowing for accurate rendering of shadows, reflections, and other lighting effects.
How do wavefronts affect the accuracy of ray tracing?
Wavefronts play a crucial role in the accuracy of ray tracing as they allow for the simulation of complex lighting effects in a scene. By tracing the path of light using wavefronts, ray tracing can accurately depict how light interacts with objects of different shapes and materials, resulting in highly realistic images.
What is the reception sphere in ray tracing?
The reception sphere is a concept used in ray tracing to determine which light rays contribute to the final color of a pixel in an image. It represents the sphere of directions from which light can potentially reach a pixel, and only light rays that intersect with this sphere are considered during the rendering process.
How does the reception sphere affect the computational cost of ray tracing?
The reception sphere plays a significant role in the computational cost of ray tracing as it determines the number of light rays that need to be traced for each pixel in an image. A larger reception sphere results in more rays being traced, which can significantly increase the time it takes to render an image.
