RC circuit - Rate o'energy dissipated = rate o'energy stored
In summary: So we cannot do this trick with the current. But the trick with the voltage works fine, because we know the voltage at the capacitor is ##V_C=E(1-e^{-\frac{t}{RC}})## and the voltage at the resistor is ##V_R=E-V_C##, so if ##V_C=V_R## then ##E=2V_C##, so ##V_C=\frac{E}{2}## as we want.
bornofflame
56
1. A 2.01 uFcapacitor that is initially uncharged is connected in series with a 6.51 kΩ resistor and an emf source with 74.6 V and negligible internal resistance. The circuit is completed at t = 0.
b) At what value of t is the rate at which electrical energy is being dissipated in the resistor equal to the rate at which electrical energy is being stored in the capacitor.
Given/Known:
##C = 2.01\cdot10^{-6} ~F##
##Q_0 = 0 ~C##
##R_1 = 6.51\cdot10^3 ~\Omega##
##\mathcal {E} = 74.6 ~V## (The source can be treated as ideal.)
##P = 854 mW## (From the prior part of the question.)
##P = Wt##
##W = \frac 1 2 CU^2##
##U = \frac 1 2 CV^2##
Using the relevant equations to solve for W:
##W = \frac 1 2 C U^2 = \frac 1 2 C\cdot (\frac 1 2 C V^2)^2 = \frac 1 8 C^2 V^4##
Plugging in numbers gives me: ##W = 31.4\cdot10^{-12}~J##
Then using ##W = Pt## to solve for ##t: t = \frac W P##, I get ##t=27.2\cdot10^{10}~s = 27.2 ~Gs##
This seems obviously wrong, I don't know exactly how many seconds it would take but this looks to be grossly out of proportion. I'm sure that the reason is because I'm not applying the equation for work properly but I'm not sure exactly what I am missing.
bornofflame said:
P=854mW
What question did that answer? The power will be varying.
Hint: you need to find the current as a function of time.
Likes bornofflame
First of all the equation ##W=Pt## is valid only when the power P is constant, independent of time t. But in the case of a charging capacitor we know that the power P (which is the rate with which capacitor energy is stored) depends on time t. The correct equation that holds for all cases is ##W=\int P(t)dt##.
There is a trick we can do to find this. Suppose ##I ## is the current at any time t and ##V_C## is the voltage at the capacitor. Then the current at the resistor is also ##I ## (connected in series) and the voltage is ##V_R=E-V_C##. The exercise asks for the time at which ##P_C=P_R\Rightarrow V_CI=V_RI\Rightarrow V_C=V_R=E-V_C\Rightarrow V_C=\frac{E}{2}##. So the requested time is that time at which the voltage at the capacitor equals ##\frac{E}{2}##.
Likes gneill and bornofflame
That was part a of this question: Just after the circuit is completed, what is the rate at which electrical energy is being dissipated in the resistor?
The answer was 855 mW.
Using the trick provided by Delta##^2## I solved for ##V_c = 37.3~V## then took ##I = \frac {dq} {dt} \rightarrow I dt = dq \rightarrow \int I dt = \int dq \rightarrow I t = Q \rightarrow t = \frac Q I##
##t = \frac {CV} I \rightarrow t = \frac {CIR} I \rightarrow t = RC = 2.01\cdot10^{-6}F \text{x} 6.51\cdot10^{-3}\Sigma = 13.1\cdot10^{-3}s##
However, according to the actual answer ##t = RC ln2 = 9.07\dot10^{-3}s##
I see that ##e## is incorporated in ##q = Q_f (1 - e^{-t / RC}) ## but I didn't end up using that in my answer. Is this the actual value for Q that I should have used in my calculations?
Er yes you should have use the equation ##q=Q_f(1-e^{-\frac{t}{RC}})## and plug in ##q=Q_f/2## (since it is ##V_C=E/2=V_f/2##)) and solve the equation
##\frac{Q_f}{2}=Q_f(1-e^{-\frac{t}{RC}})## for t.
Likes bornofflame
Up to the point where you write ##\int Idt=\int dq## you are correct but then you write ##It=Q## which is not correct, this holds only if the current is constant in time. But we know in this case the current is not constant , it goes exponentially with time (negatively exponentially to be more accurate).
So I should have continued to manipulate the equation algebraically before integrating? Replacing ##I## with something else?
Well yes you should have replaced current I with ##I=\frac{E}{R}e^{-\frac{t}{RC}}## and then do the integration and then all you ll get is the equation ##q=EC(1-e^{\frac{-t}{RC}})## which is essentially the equation for q you write after (and I mention in post #5) where ##Q_f=EC##.
Oh! Thank you! I was struggling to make the connection. I overlooked that entirely. It makes sense now. Thank you very much!
Likes Delta2
Related to RC circuit - Rate o'energy dissipated = rate o'energy stored
What is an RC circuit?
An RC circuit is a circuit that contains a resistor (R) and a capacitor (C) connected in series or parallel. The resistor limits the flow of current while the capacitor stores electrical energy.
How does energy get dissipated in an RC circuit?
When an RC circuit is connected to a power source, the capacitor begins to charge. As it charges, energy is stored in the electric field between the plates of the capacitor. When the capacitor is fully charged, there is no longer a potential difference across it and no more energy can be stored. Any additional energy from the power source is dissipated as heat in the resistor.
What is the relationship between the rate of energy dissipation and the rate of energy storage in an RC circuit?
In an RC circuit, the rate of energy dissipation is equal to the rate of energy storage. This is because the energy stored in the capacitor is being supplied by the power source at the same rate that it is being dissipated in the resistor. This relationship is described by the equation: Rate of energy dissipated = Rate of energy stored.
How does the resistance and capacitance affect the rate of energy dissipation and storage in an RC circuit?
The resistance and capacitance values in an RC circuit determine the time it takes for the capacitor to charge and discharge, which in turn affects the rate of energy dissipation and storage. A higher resistance will result in a longer charging and discharging time, while a higher capacitance will result in a faster charging and discharging time.
What are some real-life applications of RC circuits?
RC circuits are commonly used in electronic devices such as filters, oscillators, and timers. They can also be found in household appliances like televisions and air conditioning systems. Additionally, RC circuits are used in medical equipment, such as pacemakers, to control the rate of electrical pulses.
