Re-configurable Battery Network Modeling
In summary, the conversation discusses the need to model a circuit with various switches and output voltages. The circuit allows for 128 possible switch combinations, but can also be analyzed based on which batteries are in series to power the load. The conversation also addresses safety concerns and the need for correct switch settings for different battery combinations. The possibility of different circuit topologies is also mentioned, and it is up to the individual to decide if they need to be solved for.
Ambreen Mustafa
I need to model circuit given at (https://drive.google.com/file/d/0B8MN0_dZJLHZRllhV2Y0M0FnaVU/view?usp=sharing) so that we may known output for any state of switches.
Given Information: Vector of State of Switches e.g. [s11 s12 s13 s21 s22 s23 s32]. I need to model a transformation matrix which maps switches states to output voltages.
Can anyone help me with that?
An interesting problem. I don't have a full solution, but I can poke around at the start of one. First of all, I should say that there are some pretty bizarre switch combinations possible. For example, suppose $S_{32}, S_{22},$ and $S_{21}$ were closed, but all others were open. That would put $V_2$ in parallel with $V_{3}$. You don't normally do that. Whichever battery is at the higher voltage would try to charge the other battery, and because there are no circuit protection devices present, there would be no current-limiting. You can get phenomenally high currents with batteries sometimes. They're "always on". The presence of switches $S_{11}$ and $S_{21}$ is presumably to allow $V_1$ alone to power $V_{\text{out}}$, or $V_2$ to do it alone. But they raise some weird possibilities. So, while there are technically $2^7=128$ possible switch combinations, I propose to analyze the circuit differently: from which batteries you're going to put in series to power the load (which is what I'll call $V_{\text{out}}$). In this case, there are $2^3=8$ possible combinations of batteries in series to power the load. The battery combinations are: none, $V_1, V_1+V_2, V_1+V_3, V_2, V_2+V_3, V_3, V_1+V_2+V_3$. Let $x$ in a switch's configuration mean "don't care". That is, we don't care if that switch is closed or open. Let $1$ mean that a switch is closed, and $0$ mean it is open. So then, if we want no batteries to power the load, we would have
\begin{bmatrix}S_{11}\\S_{12}\\S_{13}\\S_{21}\\S_{22}\\S_{23}\\S_{32}\end{bmatrix}=
\begin{bmatrix}x\\0\\x\\x\\0\\x\\0\end{bmatrix}.$$
But note that we wouldn't want $S_{11}$ and $S_{13}$ both to be closed, because that would short out $V_2$ and cause a current spike that might even melt the wires. By the same token, we wouldn't want both $S_{21}$ and $S_{23}$ closed. These two constraints are going to be true for every configuration. In a real-world circuit, to be safer, you'd probably combine $S_{11}$ and $S_{13}$ into a single-pole, triple-throw switch in order to avoid this possibility. If we want $V_{\text{out}}=V_1$, then the necessary switch combination is
\begin{bmatrix}1\\1\\0\\1\\0\\0\\0\end{bmatrix}.$$
If we want $V_{\text{out}}=V_1+V_2$, then the necessary switch combination is
\begin{bmatrix}0\\1\\1\\1\\0\\0\\0\end{bmatrix}.$$
Can you see how to get the rest of the options?
Thanks a lot for your reply. It was really helpful. Actually i have to deduce a forward equation in which i may insert any combination of switches to get the output voltage. How can this be extended through your equation?
Well, I would say that you need to obtain the correct switch settings for the other five battery combinations first. What are those?
In this circuit there are many other topologies possible like V1 || V2, (V1+V2) ||V3, V1||V2||V3..should this switching configuration be solved for every topology? This will not give a general solution which may even be used if we add one or two more cells.
I can't answer that for you - you have to decide. As I mentioned in Post # 2, I wouldn't connect the batteries in parallel, because one would charge another, and also because they wouldn't load balance.
FAQ: Re-configurable Battery Network Modeling
What is re-configurable battery network modeling?
Re-configurable battery network modeling is a computational method used to simulate and analyze the behavior of a battery network under different operating conditions. It involves creating a mathematical model of the battery network and using computer algorithms to predict its performance.
What is the purpose of re-configurable battery network modeling?
The purpose of re-configurable battery network modeling is to improve the design and performance of battery networks by identifying potential issues and optimizing the network's configuration. It can also be used to predict the behavior of a battery network under different load conditions and to assess its reliability and durability.
What factors are considered in re-configurable battery network modeling?
Re-configurable battery network modeling takes into account various factors such as the type and chemistry of batteries used, the network's topology and configuration, the operating conditions (temperature, load, etc.), and the battery management system (BMS) algorithms.
How accurate is re-configurable battery network modeling?
The accuracy of re-configurable battery network modeling depends on the quality and completeness of the input data and the complexity of the model. With proper calibration and validation, it can provide accurate predictions of the battery network's behavior.
How is re-configurable battery network modeling used in research and development?
Re-configurable battery network modeling is widely used in research and development to optimize the design of battery networks and to assess the feasibility of new battery technologies. It can also be used to simulate and analyze the performance of battery networks in real-world applications, such as electric vehicles and renewable energy systems.
