Re: This Week's Finds in Mathematical Physics (Week 232)
The total deficit in the general case is 2pi times the Euler characteristic of the manifold. This solution can also be extended to "polyhedra" formed by triangulating any compact 2-manifold and putting flat metrics on the triangles. In this case, the total deficit will be 2pi times the Euler characteristic of the manifold. The only new case is a flat torus, which has some parameters. If the manifold is not required to be compact and some infinite triangles are allowed, the total deficit can range from 0 to 2pi. There are also more static solutions if timelike loops are allowed.
Greg Egan
Ralph Hartley wrote:
>Consider a polyhedron inscribed in a sphere of radius 1, centered at the
>origin. Let the surface of the polyhedron inherit the metric from R^3
>(which will be flat except at the vertexes).
>For any point p other than the origin, let p_1 be the intersection of
>the polyhedron with the ray from the origin through p. Let t(p) = |p|/|p_1|.
>The metric (on R^3-O) ds^2 = -dt(p)^2 + dp_1^2 is flat except at the
>rays from the origin through the vertexes, and any [space]like surface has
>total deficit 4Pi.
That's a really elegant construction, but (at least in the static case) I
think you can get rid of your Big Bang at t=0. Just take the Cartesian
product of the real line R with the polyhedron, with its inherited
metric, and put ds^2 = -dt^2 + dp_1^2, where now p_1 is the projection
from the Cartesian pair (t,p_1).
This would generalise to "polyhedra" formed by triangulating any compact
2-manifold and putting flat metrics on the triangles. The total deficit
in the general case will be 2pi*chi, where chi is the Euler
>> total deficit 4Pi.
Yes, I realized, just after sending, that the area is constant, and the
space is just R x Polyhedron. The sphere was not needed either, any
convex polyhedron would do.
I'm pretty sure that the edges of the polyhedron are purely artifacts of
the construction as well. The space is flat except at the vertexes.
Given a reference frame on one face, you can extend it to the whole
space in many different ways, one for each way of cutting the polyhedron
up and spreading it out flat. How many there are depends on what you
count as a "different" cutting.
If you require the manifold to be orientable, and don't allow negative
masses, I think the only new case is a flat torus (which does have some
parameters).
If you don't require that it be compact (and allow some infinite
triangles), you get the cases with deficit between 0 and 2Pi.
Lets see, how many more static solutions are there? If you allow
timelike loops, quite a few more I think.
Ralph Hartley
Thank you for your comment, Ralph. Your suggestion is indeed a clever way to eliminate the Big Bang singularity in this construction. It's interesting to see how this approach can be extended to other compact 2-manifolds. I will definitely explore this idea further. Thanks for sharing!
Related to Re: This Week's Finds in Mathematical Physics (Week 232)
1. What is "This Week's Finds in Mathematical Physics (Week 232)"?
"This Week's Finds in Mathematical Physics (Week 232)" is a weekly online column written by John Baez, a mathematical physicist at the University of California, Riverside. It covers a wide range of topics related to mathematical physics, including recent research developments, interesting problems, and connections between different areas of physics and mathematics.
2. How often is "This Week's Finds in Mathematical Physics" updated?
The column is updated every week, usually on Fridays. John Baez has been writing it since 1993, and there are currently over 500 issues available to read on his website.
3. Who is the target audience for "This Week's Finds in Mathematical Physics"?
The target audience for the column is anyone with an interest in mathematical physics, from undergraduate students to professional researchers. John Baez's writing style is accessible and engaging, making the column enjoyable for a wide range of readers.
4. Can I contribute to "This Week's Finds in Mathematical Physics"?
Yes! John Baez welcomes contributions from readers, whether it's suggesting interesting topics or problems to cover, providing feedback, or even writing guest columns. More information on how to contribute can be found on the column's website.
5. Is "This Week's Finds in Mathematical Physics" only about current research?
No, the column covers a variety of topics, including historical developments and foundational concepts in mathematical physics. John Baez also frequently includes "excerpts from the bookshelf," recommending books and resources related to each week's topic. So even if you're not up to date on the latest research, you can still enjoy and learn from the column.
  • Classical Physics
