Reaction between Copper, Hydrogen Peroxide, and Vinegar
In summary, Ben-P conducted an experiment in which he found that when copper is submerged in a solution of vinegar and hydrogen peroxide, no reaction is occurring; however, when the copper is heated, gas is being evolved. It is unclear how the cupric ion catalyzes the decomposition of hydrogen peroxide.
Ben-P
Hey there PF,
I'm trying to determine the reaction equation for a little home experiment I've been conducting. The setup is very minimal: copper metal in a solution of 3% H2O2 and 5% CH3COOH. In reality, I'm probably missing something fairly straightforward.
The reaction occurs very slowly, but within a few minutes it becomes very clear that this is a redox reaction, seeing as solid copper is dissolving into solution. As such, the overall reaction can generally be determined by examining the half-reactions.
The first of these half-reactions is very obvious:
Cu(s) → Cu2+(aq) + 2e-
(It forms the cupric ion because the product is copper acetate, Cu(CH3COO)2).
The second reaction, however, is slightly more annoying because H2O2 can form a few different combinations of products. Seeing as it is the only available oxidizing agent, I assumed the equation was something like this:
H2O2(aq) + 2e- + 2H+(aq) → 2H2O(l)
(Hydrogen ions are donated by CH3COOH, and as they are consumed, copper (II) ions are formed, thus the net charge of the solution remains 0)
Thus, by adding these two equations together, I assumed the overall equation to be
Cu + H2O2 + 2CH3COOH → Cu(CH3COO)2 + 2H2O.
All seemed fine, until I looked at the solution again, and realized that gas was being evolved (oxygen, not hydrogen, as determined by re-ignition of a splint). My first guess was perhaps that the freshly-etched copper was acting as a catalyst for the decomposition of hydrogen peroxide. However, after removing a piece from the solution, rinsing it quickly, and placing it in a solution of just hydrogen peroxide, I wasn't able to notice any gas being evolved.
Does anyone know the actual equation, or have suggestions for possible side reactions occurring?
Hi Ben-P,http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Does a mix of vinegar and peroxide, without the copper, liberate any gas?
Does the gas appear to be forming on the copper, or coming out of solution everywhere?
Thanks for your response, NascentOxygen!
No gas is evolved by the mixture of these two solutions.
This is difficult to distinguish; during the entire reaction (as the solution goes from clear to deep blue), gas appears to form on or near the metallic copper. However, after several hours, gas is no longer being evolved on or near the copper, but gas continues to be slowly evolved by the solution.
After some quick researching (that I didn't have time for when first posting), it is clear that the cupric ion is actually known to be a catalyst for the decomposition of hydrogen peroxide, thus explaining the continual evolution of gas by the solution (probably on impurities, such as dust, acting as nucleation sites). In addition to this, during the reaction, the copper metal probably also acts as an excellent nucleation site for gas to form, thus making it appear as though the metal itself is the catalyst.
An interesting question still remains, however, and I haven't been quite able to find an available (open-access) paper discussing the subject: how is it that the cupric ion catalyzes the decomposition of hydrogen peroxide? Is the mechanism understood?
Then you are way ahead of me! Glad you got this sorted. :smile:
Good luck with your experimental studies.
So I actually carried out this experiment myself..I'm not much of a major at chemistry (im in high school)but I did discovered that when the copper was submerged in the solution of vinegar and hydrogen peroxide at room temperature.. There seemed to be no reaction going o
n,so I
heated the the mixture.After heating there seemed to be some effervescence and a gas coming off which I guess was oxygen.Where did it
from?I guess it came from the decomposition of hydrogen peroxide
Cu+H202------>heat =O2+H20
Then the copper would react with the vinegar giving you the acetate,all of this may be summarized by one equation
Cu+H202+CH3COO------>heat =Cu(CH3COO)2+H20+O2
The sequence may be that Cu metal slowly reacts with the acid to form the cupric ion. This ion being a catalyst for the decomposition of the peroxide then starts to liberate the gas.
You could try separately warming Cu with the vinegar to form some cupric ions, then decant some of this solution into a test tube of peroxide to confirm this.
Related to Reaction between Copper, Hydrogen Peroxide, and Vinegar
1. What is the purpose of mixing copper, hydrogen peroxide, and vinegar?
The purpose of mixing copper, hydrogen peroxide, and vinegar is to observe and study the chemical reaction that occurs between these substances. This reaction can provide insights into the properties and behavior of each individual substance and how they interact with each other.
2. What happens when copper is mixed with hydrogen peroxide and vinegar?
When copper is mixed with hydrogen peroxide and vinegar, a chemical reaction takes place resulting in the formation of copper oxide. This reaction is known as an oxidation-reduction reaction, where the copper is oxidized and the hydrogen peroxide is reduced.
3. What are the products of the reaction between copper, hydrogen peroxide, and vinegar?
The products of the reaction between copper, hydrogen peroxide, and vinegar are copper oxide, water, and acetic acid. The copper oxide forms a solid precipitate, while the water and acetic acid remain in the solution.
4. What factors can affect the rate of this reaction?
The rate of the reaction between copper, hydrogen peroxide, and vinegar can be affected by various factors such as temperature, concentration of the substances, and the presence of catalysts. Increasing the temperature and concentration of the substances can speed up the reaction, while the presence of a catalyst can lower the activation energy and increase the reaction rate.
5. Is the reaction between copper, hydrogen peroxide, and vinegar exothermic or endothermic?
The reaction between copper, hydrogen peroxide, and vinegar is exothermic, meaning it releases heat into the surroundings. This can be observed by an increase in temperature of the reaction mixture. The exothermic nature of the reaction is due to the formation of bonds between the atoms, which releases energy.
