Reaction energy for a Lithium Iron Phosphate battery
The discussion focuses on determining the Gibbs energy for the discharge reaction of a LiFePO4 battery, drawing parallels with the established method for Pb-Acid batteries. The user outlines the reaction for the Pb-Acid battery and calculates the specific charge density and specific energy density based on molar masses and the Faraday constant. For the LiFePO4 reaction, the user presents the overall reaction but encounters challenges in calculating molar masses due to the variable proportion 'x' in the lithium compounds involved. The user seeks clarification on the accuracy of their breakdown and inquires about alternative methods for deriving specific charge and energy densities, particularly through the comparison of reaction energies of products and reactants. The discussion emphasizes the need for precise values and methodologies to understand the energetics of the LiFePO4 reaction.
JulesP
TL;DR Summary
Working out the specific charge and energy density for a LiFePO4 battery from the reaction equation
For my battery research, I am trying to determine the reaction (Gibbs) energy for what occurs in a LiFePO4 battery as it discharges.
For reference, I have used the approach that works for a Pb-Acid battery, as laid out below using molar masses, and am then trying to do the same for the LiFePO4 reaction.
Reaction:
Pb(s) + PbO2 (s) + 4H+ (aq) + 2SO4 2- (aq) → 2PbSO4 (s) + 2H2O (l) (𝜈e = 2)
∑I Mi = 1 x M(Pb) + 1 x M(PbO2) + 2 x M(H2SO4) = (207.2) + (239.2) + (2 x 98.1) = 642.6 g/mol
Specific Charge Density = q Pb-acid
= z F / ∑I Mi = 2 x 26.8 / 642.6 = 0.0834 Ah/g = 83.4 Ah/kg (where F is the Faraday constant)
Specific Energy Density = q x EOcell = 83.4 x 2.06 = 171.8 Wh/kg
For the Lithium Iron Phosphate, the overall reaction is:
LiFePO4 + 6xC ⇄ Li(1-x)FePO4 + Li(x)C6
∑I Mi = 1 x M(LiFePO4) + 6 x M(C) + 1 x M(Li(1-x)FePO4) + 1xM(Li(x)C6) = (158) + (36) + (??) + (??) = ??? g/mol
Clearly, due to the variable proportion ‘x’, it is hard to be precise about the molar masses of some of these components.
So my query is firstly, is the above breakdown correct and secondly, is there a better way to derive the specific charge and energy densities for the Lithium reaction, perhaps using the (Reaction energies of products) - (Reaction energies of the reactants)?
Can anyone please help me clarify the energetics of this reaction and the sources of any values used?
Thank you
Julian
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
