Reaction force at the top of a rollercoaster loop
In summary: Instead, the two forces are two aspects of one and the same interaction.In summary, when a rollercoaster cart goes through a loop, the centripetal force needed to keep it in a circular path is created by the combination of the cart's weight and the reaction force of the track pushing back on the cart. However, the source of this reaction force is not the cart's velocity or acceleration, but rather the rails themselves. This is due to the fact that the rails are constantly applying a force on the cart to keep it in a curved path, despite the cart's tendency to move in a straight line. As per Newton's Third Law, the cart also exerts an equal and opposite force on the rails, but this force is
dainckp
I understand that in a rollercoaster loop, two forces combine to make the centripetal force required to keep the cart moving in a circular path - the cart's weight, and the reaction force of the track against the cart (except in the special case where the cart's weight alone is sufficient for the centripetal force)
What I don't understand is, why is there a reaction force at all? If the rails are pushing back on the cart, by Newton's Third Law the cart must be in the first place exerting an equal and opposite force on the rails, but I can't see where such a force would come from. The cart's velocity is perpendicular to the rail, and the acceleration is directed towards the centre of the loop, and I was taught there is no such thing as an outward centrifugal force, so why does the cart push on the rails in the first place?
A reaction force yes, but a reaction to what?
Welcome to PF!
The force is from (or, rather, causes) part of the acceleration: f=ma. Gravity causes the rest.
The cart wants to go in a straight line but the rails force the cart to move in a curve. eg The rails apply a force on the cart.
dainckp said:
If the rails are pushing back on the cart, by Newton's Third Law the cart must be in the first place...
No, not "in the first place". The two equal and opposite forces act simultaneously, and are on the same footing. There is no cause-effect relationship between them, contrary to what the unfortunate naming "action & reaction" suggests.
Thank you for your question. As you mentioned, according to Newton's Third Law, for every action there is an equal and opposite reaction. In the case of a rollercoaster loop, the reaction force at the top of the loop is a result of the cart's weight and its velocity as it moves through the loop.
When the cart is at the top of the loop, its weight is acting downwards towards the ground. At the same time, the cart's velocity is directed tangent to the loop, meaning it is moving horizontally. These two forces combine to create a resultant force that is directed towards the center of the loop, which is necessary for the cart to maintain its circular motion.
The reaction force of the track against the cart is the equal and opposite force to this resultant force. It is necessary for the track to exert this reaction force in order to keep the cart moving in its circular path. Without this reaction force, the cart would not be able to maintain its speed and direction and would fly off the track.
So, in summary, the reaction force at the top of the rollercoaster loop is a result of the cart's weight and its velocity, and it is necessary for the cart to maintain its circular motion. I hope this helps to clarify any confusion. Let me know if you have any further questions.
Related to Reaction force at the top of a rollercoaster loop
What is reaction force at the top of a rollercoaster loop?
The reaction force at the top of a rollercoaster loop refers to the force that is exerted on a rider at the highest point of the loop. This force is responsible for keeping the rider in their seat and preventing them from falling out of the rollercoaster.
How is the reaction force at the top of a rollercoaster loop calculated?
The reaction force at the top of a rollercoaster loop is calculated by using Newton's second law of motion, which states that force is equal to mass multiplied by acceleration. In this case, the acceleration is the centripetal acceleration, which is the force that keeps the rider moving in a circular motion around the loop.
What factors affect the magnitude of the reaction force at the top of a rollercoaster loop?
The magnitude of the reaction force at the top of a rollercoaster loop is affected by several factors, including the speed of the rollercoaster, the mass of the rider, and the radius of the loop. The faster the rollercoaster is moving, the greater the reaction force will be. A heavier rider will also experience a greater reaction force, and a smaller radius of the loop will result in a stronger reaction force.
Is the reaction force at the top of a rollercoaster loop dangerous?
The reaction force at the top of a rollercoaster loop is not necessarily dangerous, as it is designed to keep riders safely in their seats. However, if the force is too strong, it can cause discomfort or even injury to riders, which is why rollercoasters are carefully designed and tested to ensure they are safe for riders.
How does the reaction force at the top of a rollercoaster loop contribute to the overall thrill of the ride?
The reaction force at the top of a rollercoaster loop is a crucial element in creating the thrill of the ride. The combination of speed, acceleration, and the feeling of being suspended upside down all contribute to the excitement and adrenaline rush experienced by riders. Without the reaction force, the ride would not be as thrilling or exciting.
  • Classical Physics
  • Mechanical Engineering
