Reaction of gases/ gas stoichiometry
In summary, the conversation discusses a chemistry problem involving the reaction of H2 and N2 gases to produce NH3. The question is how many mL of product will be produced from a given amount of reactants. The conversation also mentions the use of Avogadro's Law and the concept of limiting reagents. Another problem is mentioned, where the answer is 50mL of product instead of the expected 100mL.
apbuiii
The reaction of 50 mL of H2 gas and 50 mL of N2 gas via the equation: 3H2 + N2 ---> 2NH3 will produce how many mL of product? A reaction of 25 mL of Hydrogen gas and 75 mL of Nitrogen gas? Assume that temperature and pressure are constant.
Avogadro's Law
I know that Volume of gases at STP are proportional to the moles of gas present, so the ratios are 3:1:2, and that i mole of ideal gas is 22.4 L. I'm not totally sure as to where to go from here. Is it kind of a limiting reagent because they give me the volumes of each reactant? Please help. Thanks!
It is just a simple limiting reagent, with volumes instead of moles - but, as you have already mentioned, in this case moles and volume can be used interchangeably.
Okay thank you. Well, I asked this question because of this problem: The reaction of 50 mL of chlorine gas with 50 mL of Ethylene gas Cl2 (g) + C2H4 (g) = C2H4Cl2 (g). How many mL of product will be produced? The answer is 50mL but I don't understand why. Since there is 50 mL of chorine and 50 mL of ethylene, shouldn't there be 100 mL of product? But instead, the answer is just 50 mL...
Take a look at the reaction equation. How many moles (total) on the left? How many moles on the right?
I can provide a response to this question by using the principles of gas stoichiometry. First, we need to convert the given volumes of gases (50 mL and 50 mL) into moles using the ideal gas law:
PV = nRT
Where P is pressure, V is volume, n is the number of moles, R is the gas constant, and T is temperature. Since the temperature and pressure are constant, we can use the simplified form of the equation, which is n = V/22.4.
For the first reaction, we have:
nH2 = 50 mL/22.4 mL/mol = 2.23 moles
nN2 = 50 mL/22.4 mL/mol = 2.23 moles
Using the balanced chemical equation, we can see that for every 3 moles of H2, we get 2 moles of NH3. Therefore, we have a limiting reagent (H2) and the amount of NH3 produced will be based on the amount of H2 present.
nNH3 = 2.23 moles H2 x (2 moles NH3/3 moles H2) = 1.49 moles NH3
To convert this back to volume, we use the same equation as before:
V = n x 22.4
VNH3 = 1.49 moles x 22.4 mL/mol = 33.4 mL NH3
For the second reaction, we follow the same steps:
nH2 = 25 mL/22.4 mL/mol = 1.12 moles
nN2 = 75 mL/22.4 mL/mol = 3.34 moles
Again, H2 is the limiting reagent and we use the same conversion to find the amount of NH3 produced:
nNH3 = 1.12 moles H2 x (2 moles NH3/3 moles H2) = 0.74 moles NH3
VNH3 = 0.74 moles x 22.4 mL/mol = 16.6 mL NH3
In summary, for the first reaction, 33.4 mL of NH3 will be produced, and for the second reaction, 16.6 mL of NH3 will be produced. It is important to note that these calculations assume ideal gas behavior and may not
Related to Reaction of gases/ gas stoichiometry
What is the reaction of gases?
The reaction of gases refers to the chemical reactions that occur between different gases. These reactions involve the breaking and forming of chemical bonds between gas molecules, resulting in the formation of new substances.
What is gas stoichiometry?
Gas stoichiometry is the branch of chemistry that deals with the quantitative relationships between reactants and products in gas phase reactions. It involves using the ideal gas law and other mathematical calculations to determine the amount of reactants and products involved in a chemical reaction.
How is gas stoichiometry different from regular stoichiometry?
Gas stoichiometry differs from regular stoichiometry in that it takes into account the volume and pressure of gases, in addition to the mass and moles of substances. It also uses the ideal gas law, while regular stoichiometry uses the mole ratio from a balanced chemical equation.
What is the ideal gas law?
The ideal gas law is a mathematical equation that relates the pressure, volume, temperature, and number of moles of an ideal gas. It is represented as PV = nRT, where P is pressure, V is volume, n is the number of moles, R is the gas constant, and T is temperature.
How is the ideal gas law used in gas stoichiometry?
The ideal gas law is used in gas stoichiometry to convert between the different units of pressure, volume, temperature, and number of moles. It is also used to calculate the number of moles of a gas present in a given volume at a specific temperature and pressure, which is then used to determine the stoichiometry of a gas phase reaction.
16K
  • Mechanical Engineering
