Reaction Rate experiment: Potassium Permanganate and Hydrogen Peroxide
The experiment involved reacting potassium permanganate with hydrogen peroxide and vinegar, resulting in a color change from purple to colorless, indicating the completion of the reaction. The reaction rate was calculated as the concentration of KMnO4 divided by time, and the results were plotted against varying concentrations of KMnO4, showing an exponential fit. The observed curve shape suggests that the instantaneous reaction rate is influenced by the amount of the limiting reactant present. Maintaining excess peroxide allows for clear observation of the color change, while keeping the concentrations of peroxide and acetic acid constant implies a second-order reaction with respect to KMnO4. The discussion highlights the relationship between reactant concentration and reaction rate, suggesting further exploration of different limiting reactants could yield varied results.
neilparker62
Mentor
Education Advisor
Insights Author
TL;DR
Relationship between reaction rate and concentration when Potassium Permanganate reacts with excess Hydrogen Peroxide in acidic medium.
I am picking up on an old thread having revisited the associated experiment.
https://www.physicsforums.com/threa...ganate-and-hydrogen-peroxide-solution.992713/
10ml of Permanganate solution (0.0135 mol/liter) were reacted with 10ml of Peroxide and 10ml of vinegar. The peroxide was in excess so all the permanganate reacted changing from purple to colourless. This colour change was timed for various dilutions of the permanganate. For example, one run would consist of 8ml stock permanganate and 2ml distilled water reacted with the 10ml peroxide and 10ml vinegar. Constant volume of 30ml was thus maintained.
Reaction rate was determined as [KMnO4] / t . and plotted against [K Mn O4]. I'm not sure how valid it is to plot x/t vs x but that's what we did yielding following data and graph. Well it seems to show a pretty good exponential fit and my question is where does that come from? Have trawled the internet but can't find anything similar except maybe the well know sodium thiosulphate reaction rate experiment.
https://www.desmos.com/calculator/fdkytmcxgy
Chemistry news on Phys.org
google rate laws graphs
Likes neilparker62
I'm assuming that your question is 'big-picture.'
The curve shape is the result of the fact that the instantaneous rate of reaction is controlled by how much of the limiting reactant remains - and that you are monitoring that specific reactant. If you did the same experiment (monitoring permanganate) with a much-reduced peroxide concentration (making it the limiter), you'd see a different relationship.
Likes neilparker62
I think the aim was to have the peroxide well in excess so that you would definitely see the purple colour disappear and could time how long that took. If the concentration of peroxide and of acetic acid (from vinegar) is kept constant , then rate should be proportional to [KMnO4].^2 - second order ? Did get something suggesting a straight line graph plotting 1/t vs [KMnO4] or 1/[KMnO4] vs t.
  • · Replies 26 ·
10K
22K
