B Reactionless Drive Using Light Bouncing Off Moving Mirrors
alas666
Poster has been reminded that we do not allow discussions about Reactionless Drives
TL;DR Summary
reactionless drive, relativistic Doppler, reflection from moving mirror
Here is a concept suggesting reactionless drive:
Setup: A light pulse of wavelength l0 bouncing between 2 mirrors one on the left - ML and one on the right - MR. Each mirror oscillates perpendicularly to light travel direction attaining relativistic speeds vl, vr. Light pulse is timed so it reflects from the ML, moving with vl, when it is moving in the same direction as light pulse, while reflection from MR happens when vr opposes light direction.
Analysis: The reflecting photon momentum change is dp = 2h/l. The wavelength lL=l0((1+vl/c)/(1-vl/c))^-1 is red shifted in ML reference frame, while MR wavelength IR = l0*((1-vl/c)/(1+vl/c))^-1 is blue shifted, as per wikipedia relativistic Doppler effect. The traveling light is changing a wavelength at each reflection in setup reference frame: lL = l0 (1-(vl/c)^2)/(1-2vl/c+(vl/c)^2) - red shifted, IR = I0 (1-(vr/c)^2)/(1+2vr/c+(vr/c)^2) - blue shifted (see https://arxiv.org/pdf/1207.0998.pdf). To maintain wavelength unchanged after 2 bounces one have to assure that vl, vr selected correctly.
Conclusion: Because change of the momentum in mirror reference frame is different for MR and ML there is a resulting net momentum change impacting setup.
where have I wronged ?
A. Thinking that PF ios a good place to discuss personal theories.
B. Thinking momentum is not conserved.
  • Haha
Likes Grasshopper, russ_watters and Dale
alas666 said:
Summary:: reactionless drive, relativistic Doppler, reflection from moving mirror
Per the PF Rules (see INFO at the top of the page), we do not discuss reactionless drives. Thread is closed.
Forbidden Topics said:
EMDrive and other reactionless drives
See https://www.physicsforums.com/threads/nasas-em-drive.884753/
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
