Reactor fail-safe shutdown at any power density?
In summary: The steam is then used to drive the turbines. In this case, the moderator is always there, and you can't get rid of it. So in the event of a loss of cooling, you would still have the moderator to decay.In summary, if SCRAM completely removed all moderator from the reactor, would decay heat still be an issue?My understanding of how decay heat occurs after shutdown in large scale Nuclear Power Reactors. Is that Beta Decay causes residual Neutron activity at a small fraction of the operating power level. This however is potentially still enough to damage plant and equipment in the event of a loss of cooling incident.First thing first, is my understanding of the process correct?If so
The_engine_ear
TL;DR Summary
If SCRAM completely removed all moderator from the reactor, would decay heat still be an issue?
Summary: If SCRAM completely removed all moderator from the reactor, would decay heat still be an issue?
If so, in the absence of a moderator, are these neutrons in the fast or thermal spectrum?
If it's the former, why not use a separate cooling loop on a PHWR?
Then just install a burst disk on the bottom of the pressurized reactor vessel. This way any over temperature event corresponds to a rise in pressure within the reactor vessel. The burst disk can be relied upon to fail open, at which time 100% of the heavy water moderator would instantly flash to steam, venting into a storage tank. To my way of thinking this would offer a fail-safe shutdown mode similar to LFTR designs, but should however operate much faster than a freeze plug.
Am I correct in my reasoning that complete removal of the heavy water moderator, eliminates decay heat after scram?
Decay heat is independent of neutrons. It is just beta decays (and a few alpha decays) from radioactive materials. Removing the moderator doesn't do anything about it*, you need to cool the reactor.
*well, if the moderator is also the cooling liquid then you remove the ability to cool the core, a really bad idea
Decay heat arises from the full range of decay of fission product and activation product. There are betas, alphas, gammas, and even a few delayed neutrons.
As you move to through the periodic table to higher numbers of protons, you find you need a larger number of neutrons to make it stable. Helium is 2 protons and 2 neutrons. Lead is 82 protons and 122 to 126 neutrons, depending on the isotope. When a nucleus fissions, typically the results have too many neutrons to be stable. This means they will be radioactive. Betas and alphas are ways to adjust this to come to a stable isotope. But they can also emit neutrons, and they often emit a couple gammas on the way.
The fission products build up during operation. They don't go away at shutdown, but continue to decay.
At the moment of a reactor shutdown, depending on the design, decay heat is typical a few percent of full power, typically in the range of 4% to 6%. After a few minutes it will have fallen to 1% to 2%. The decay curve is very complicated because it is the result of many different isotopes with very different half lives. The specific design of the reactor, and the operating history prior to shutdown, have strong effects on the curve. So it's not possible to give an exact value for it. Probably the delayed neutrons are the fastest to decay, with half lives mostly less than about 2 minutes. Though a few hang in there with half lives of a couple hours. After that the gammas are probably the fastest decaying, though again, a few hang in there with intermediate half lives.
So the exact fraction of the decay heat each decay mode produces is changing over time, and is different for different reactors, and different for different operating histories.
Some reactor designs are such that they can passively dissipate the decay heat after a shutdown. Usually this is only for quite small reactors, in the few megawatt range or less. For example, pool type reactors are often designed this way. If you have a reactor about 1 meter on a side in a pool with 100 tons of water, you can probably count on the decay heat being absorbed by the pool. At least for many days which should give you time to correct whatever the problem is. Many research reactors are designed this way.
Typically a large power reactor, say above 1000 MW thermal, will have too much fuel for this to work. At 2% decay heat that's still 20 MW. It means the heat is enough, and the heat dissipation poor enough, that temperatures can rise drastically. You can get melting of metal components. You can get production of hydrogen with the possibility of explosion. You can even get the metal components catching on fire and sucking the oxygen out of the cooling water. This can raise the temperature in the core to extreme levels, say in the few-thousand degrees range.
Some reactor designs combine the coolant and moderator. The fuel is in a big pressurized tank in which you pump in water and get out much hotter water, or possibly steam. It's not possible to separate coolant from moderator in such designs.
Some molten salt reactor designs include the ability to dump the entire working material of the core into a "catcher" under the core. This is designed with a geometry that splits the material into sub-critical regions, and passively absorbs the decay heat for arbitrarily long periods. This is where the burst valve you mention comes in. A plug of material melts if the reactor ever goes above its operating temperature, and the molten fuel drains out. Nobody has built anything with such a design, but it seems on paper to be a good idea.
The rest of this is about CANDU reactors. You can get lots of other info on them here.
https://canteach.candu.org/Pages/Welcome.aspx
In a CANDU reactor, the coolant and moderator are separate. The coolant is in pressurized horizontal fuel channels. The fuel is loaded into the channels from the end of the reactor. The moderator is in a non-pressurized tank so that the moderator fills the space between the fuel channels. The fuel channels are typically pressurized to about 9 MPa or so, and are at temperatures just below boiling, approximately 250°C. The moderator is typically about 60°C. There is typically about 50 tonnes of moderator.
In early designs of CANDU there was a shutdown by dumping the moderator. There were huge valves at the bottom, with a catch tank. The moderator could be drained in some small time like 1.5 seconds, basically a little more than the time it takes to fall 6 meters. However, accident analysis convinced people it was a bad idea. Dumping 50 tonnes of cold water just at the moment an accident was happening turned out to be sub-optimal.
So CANDU has two fast acting shutdown systems. They have control rods, typical absorber rods (maybe Gadolinium, Boron, or Cadmium) that are dropped into the core to absorb neutrons. And they have a liquid absorber injection system that injects neutron absorbing material (typically Gadolinium or Boron) into the moderator.
Also, CANDU has an emergency coolant injection system (ECIS). This is a large tank of cold water that stands by to replenish the coolant in the event of a loss of coolant accident. And, in a severe situation, there is a fitting that permits connecting a fire hose to the reactor to supply coolant.
Likes krater
It is possible to design a reactor to be passively safe after shutdown where there is no chance of meltdown. Such as using natural circulation like the ESBWR design. Or, having a reactor small enough so there is less decay heat and more surface area.
Yes, there are plenty of designs for that. Do a google search for intrinsicly safe nuclear reactor.
My own company, ASEA ATOM, had a great concept for one called SECURE. We were about to announce the contract to place the first one in downtown Helsinki, but the day before the press conference, Chernobyl happened.https://www.osti.gov/biblio/5446865
Related to Reactor fail-safe shutdown at any power density?
1. What is a reactor fail-safe shutdown?
A reactor fail-safe shutdown is a safety mechanism that is designed to automatically shut down a nuclear reactor in the event of an emergency or abnormal conditions. This is done to prevent any potential accidents or damage to the reactor.
2. How does a reactor fail-safe shutdown work?
A reactor fail-safe shutdown works by using various sensors and control systems to detect any abnormal conditions or malfunctions in the reactor. If these conditions are detected, the control systems will automatically initiate a shutdown sequence, which stops the nuclear reaction and cools down the reactor.
3. Why is it important to have a fail-safe shutdown in a reactor?
A fail-safe shutdown is crucial for the safety of a nuclear reactor and the surrounding environment. It ensures that in the event of an emergency, the reactor will shut down and prevent any potential accidents or releases of radioactive material.
4. Can a reactor fail-safe shutdown be manually activated?
Yes, in addition to automatic activation, a reactor fail-safe shutdown can also be manually activated by trained personnel. This can be done in the event of a malfunction or emergency situation that requires immediate shutdown.
5. What is the role of power density in a reactor fail-safe shutdown?
Power density refers to the amount of energy being produced per unit volume in a nuclear reactor. In a fail-safe shutdown, power density is closely monitored and controlled to ensure that it stays within safe limits. If the power density exceeds these limits, the shutdown sequence will be initiated to prevent any potential accidents or damage to the reactor.
  • Nuclear Engineering
