Reading of a voltmeter and an ammeter
In summary: This means that they will only read a very small current and may not be able to measure a potential difference at all.
Jahnavi
848
102
Part a)
Voltmeter can be replaced by an open circuit and ammeter can be replaced by a short circuit .By doing so the current flows in the outer loop consisting of both the batteries and both the resisters .The current in the circuit is given by i = (45-15)/(20+10) = 1A .
Potential drop across Voltmeter is U2-iR2 = 45-(1)(20) = 25 V
So reading of ammeter is 1A and that of voltmeter is 25V .
Is that the correct answer for part a) ?
I am having some trouble with the use of "ideal voltmeter" .An ideal voltmeter has infinite resistance .It can be replaced by an open circuit . But if voltmeter has to read a potential difference it must draw some current .If no current flows through the voltmeter ,then it's reading would be simply zero .
Sorry for being a bit confused .
yes
Your analysis is correct, BUT ... ideal volt meters are assumed to draw an infinitesimally small current that has zero effect on the circuit. It's a problem-simplification technique.
Likes Jahnavi
OK
And in part b) when the two meters are interchanged
No current flows through U1 and R1 , so entire terminal voltage of U1 appears across the voltmeter .It reads 15V .
Current flows in the loop consisting ammeter and U2 and R2 .Current i = 45/20 = 2.25A .
Ammeter reads 2.25A and voltmeter reads 15V .
I hope this part is also correct .
Yes.
Likes Jahnavi
Just for info... Some specialist Voltmeters have very high input resistance, as much as 10*109 Ohms on some ranges.
FAQ: Reading of a voltmeter and an ammeter
What is the purpose of a voltmeter and an ammeter?
A voltmeter is a measuring instrument used to measure the electrical potential difference between two points in a circuit. An ammeter, on the other hand, is used to measure the flow of electric current in a circuit.
How do you read a voltmeter and an ammeter?
To read a voltmeter, you need to connect the positive lead to the positive terminal of the circuit and the negative lead to the negative terminal. The reading is then displayed in volts. For an ammeter, you need to break the circuit and connect the leads in series with the circuit. The reading is then displayed in amperes.
What is the difference between a voltmeter and an ammeter?
The main difference between a voltmeter and an ammeter is the quantity that they measure. A voltmeter measures voltage, while an ammeter measures current. Additionally, voltmeters are connected in parallel to the circuit, while ammeters are connected in series.
What is the importance of using a voltmeter and an ammeter in a circuit?
Using a voltmeter and an ammeter in a circuit allows you to measure the voltage and current, respectively, which are important parameters in understanding the behavior and performance of the circuit. It also helps in troubleshooting and detecting any potential issues in the circuit.
Can a voltmeter and an ammeter be used interchangeably?
No, a voltmeter and an ammeter cannot be used interchangeably. They are designed to measure different quantities and have different connections in the circuit. Using one in place of the other can result in inaccurate readings and potentially damage the instrument.
14K
