Reading Steam Tables for Saturated Liquid Not Vapor
In summary, when finding the enthalpy of water entering the boiler in the Rankine cycle, it is important to use the enthalpy value at boiler conditions for a saturated liquid. This is because when the steam condenses in the condenser, it turns into saturated liquid at a low pressure and temperature. To find the enthalpy of saturated liquid water, one can use steam tables, specifically the "Saturated Water" or "Saturated Liquid" tables. These tables can be indexed by either saturation temperature or saturation pressure. It is important to note that using units from different systems, such as imperial units for pressure and SI for temperature, can lead to confusion and potential errors. It may also be necessary to interpolate to find the ent
JeweliaHeart
68
Hello, I have an assignment that centers around the Rankine cycle and requires me to find the enthalpy of water entering the boiler. My professor has told me to take the enthalpy value at boiler conditions for a saturated liquid.
I'm not really sure why I should make this assumption as I was under the impression that the water reached saturation as it heated over time in the boiler. Therefore, it would not be a saturated liquid just yet as it entered the boiler.
Anyhow, I set out to find the enthalpy of the saturated liquid water using steam tables, but all the steam tables I come across so far only give values for the saturated steam, not liquid. I'm not sure if I'm simply not reading it properly. However, I'm unsure of how to get the value for the enthalpy of a saturated liquid when only the enthalpy of saturated steams are given.
Any help would be appreciated.
No need to pick an argument with your professor over this point, unless you have a steam plant operator's license.
Actually, when the steam condenses in the condenser, it turns into saturated liquid at that point, just at a low pressure and temperature.
https://en.wikipedia.org/wiki/Rankine_cycle
You're not looking in the right portion of the steam tables then. The tables you are looking for should be the "Saturated Water" or "Saturated Liquid" tables. If your tables say "Superheated Vapor", you're in the wrong location.
The saturated liquid tables can be indexed either by Tsat or Psat, and your tables may contain both. Remember, for a Psat = 1.0 atm., Tsat = 100 °C. The associated properties listed in these tables should give values for the specific volume, enthaply, entropy, etc. for fully saturated liquid and fully saturated vapor.
Okay. Thank you for explaining why the water enters the boiler as a saturated liquid. It makes much more sense now.
Please help me along here...
I found a table at this link: http://holbert.faculty.asu.edu/eee463/SteamTable.pdf.
It is called a "Saturated Water Table". The boiler conditions are 187 degrees Celsius and 112 psia. I'm not sure whether to choose the temperature or pressure as a reference point.
First of all, I don't recommend mixing units from different systems. Using imperial units for pressure and SI for temperature is asking for trouble. You don't specify if you want the enthalpy of the water in BTU/lbm or kJ/kg. Given the conditions you have listed, it looks like you'll have to interpolate to find the enthalpy of your water.
The tables you have posted are for thermo properties in Imperial Units. You can find similar thermo tables for water in SI units.
One is attached at the bottom of this post. The properties of the saturated liquid indexed by saturation temperature start on p. 890; indexed by saturation pressure begin on p. 892.
  • Thermodynamic_tables_SI.pdf
Thanks for that handy table. I'm supposed to get the enthalpy in kJ/kg, so that table is just right.
Now here is where I am confused. Under 187 degrees Celsius and 112 psia, the water is actually a superheated vapor. Therefore, I'm guessing that I'm supposed to choose only one value for the saturation conditions and then find the corresponding temperature or pressure. Does it matter whether I choose the 187 degrees Celsius or the 112 psig, or won't I get the same answer either way?
I think you may still be having problems with your units. 112 psia is equivalent to 772.2 kPa. SI units for pressure are Pascals (Pa), not pounds per square inch (psi).
The tables I have attached are abbreviated. If your temperature and pressure combination falls too far off the saturation line, expanded tables may be required to find the enthalpy you are looking for.
I was under the impression that the temperature and pressure of saturated steam are mutually dependent. Therefore, the water can not be a saturated liquid/vapor at those conditions, but it is rather a super-heated vapor.
I think what I am supposed to do is perhaps choose the 112 psia as the reference temperature because in the boiler heat addition occurs at constant pressure.
Both the 112 psia and 187 Celsius represent average pressure and temperature values in the boiler respectively. Do you think that this is a correct assumption?
I don't think that converting between units will really be a problem with all the online conversion calculators available.
psia is not used to measure temperature.
It's not clear what you mean by "average pressure and temperature values in the boiler". Boilers are designed to produce steam at a given temperature and pressure. The feed water may be taken into the boiler at a lower temperature than the outlet conditions specify, but it must be pumped into the boiler at a greater pressure than what is present in the steam drum, otherwise water would flow out of the boiler back into the feed water system.
In order to avoid pointless back and forth here, please post the particulars of the boiler or the problem statement of the assignment you're working on.
Sorry, I meant to say reference 'pressure', not temperature.
I will post the assignment PDF here as an upload.
We used something called a Rankine Cycler which has an attached laptop that records the steady state temperature and pressure of the various equipment(boiler, turbine, etc.) over very small time increments, and then imports the data into an Excel spreadsheet.
To find boiler inlet and outlet temperature/pressure, I was told to take the average of the reported values at steady state. This what I meant by average.
  • RC-2015.pdf
Here is the actual assignment spreadsheet where I am asked to perform certain calculations. It was already graded, but I'm making corrections in order to do my short report. Hopefully, this will make my questions make more sense.
  • graded__RCPostlab_tue318L002.xlsx
Well, for the feed inlet conditions, you appear to need compressed liquid tables, rather than saturated liquid or steam tables.
Compressed liquid tables and superheated vapor tables from the NIST can be found here:
http://www.nist.gov/srd/upload/NISTIR5078-Tab3.pdf
The horizontal bar in these tables represents the saturation line.
The rest of these tables and notes are here:
http://www.nist.gov/srd/upload/NISTIR5078.htm
You can use Table 3 to check the enthalpy, h1, of the feed water at the inlet to the boiler. Remember to use the pressure of the feed water in MPa rather than psia for these tables. Some interpolation will be required.
As far as the rest of the data is concerned, there is quite a drop in steam pressure temperature between the outlet of the boiler and the inlet to the turbine. You want to use superheated steam in a turbine to maximize power production and minimize erosion of the turbine blades due to moisture impingement.
Related to Reading Steam Tables for Saturated Liquid Not Vapor
1. What is a steam table?
A steam table is a tool used by engineers and scientists to determine the properties of water and steam at different temperatures and pressures. It provides a convenient way to find key values such as temperature, pressure, specific volume, and enthalpy for both saturated liquid and vapor states.
2. How do I read a steam table for saturated liquid?
To read a steam table for saturated liquid, you need to locate the temperature and pressure values for the specific state of water. Then, find the corresponding values for specific volume, internal energy, and enthalpy. These values are typically listed in columns and rows on the steam table.
3. What is the difference between saturated liquid and vapor?
Saturated liquid is a state of water where it exists purely as a liquid at a given temperature and pressure. Saturated vapor, on the other hand, is when water exists purely as a gas at a given temperature and pressure. Both states can coexist in equilibrium at a specific temperature and pressure.
4. How are steam tables helpful in engineering?
Steam tables are essential tools in engineering because they provide vital information about the properties of water and steam, which are commonly used in many industrial processes. Engineers can use this information to design and optimize systems that use water and steam, such as power plants, refrigeration systems, and boilers.
5. Are there any limitations to using steam tables?
While steam tables are useful tools, they do have limitations. They only provide data for water and steam at specific temperatures and pressures. Additionally, they assume ideal conditions and do not account for any impurities or non-ideal behavior that may occur in real-world systems.
  • Materials and Chemical Engineering
