Real Analysis Least Upper Bound Question
In summary, to prove that lub(x + y : x in S_1, y in S_2) = lub(S_1) + lub(S_2), you need to show that for any \epsilon > 0, there exist elements x in S_1 and y in S_2 such that x + y > lub(S_1) + lub(S_2) - \epsilon. This can be done using the least upper bound property and manipulating inequalities.
utstatistics
If S1, S2 are nonempty subsets of ℝ that are bounded from above, prove that
l.u.b. {x+y : x \in S1, y \in S2 } = l.u.b. S1 + l.u.b. S2
Least Upper Bound Property
Using the least upper bound property, let us suppose that a is an upper bound for S1 and b is an upper bound for S2, as they are both a set of real numbers. Then there exists an x in S1 s.t. x≤a and there exists a y in S2 s.t. y≤b. By adding them together, x+y≤a+b where a and b are the upper bounds for their respected set of real numbers. Thus, it is equal to l.u.b. S1 + l.u.b. S2
I think this is how it goes. I'm sorry if my proof is horrible; it has been a significant period of time since I've done proofs, as statistics and probability classes don't use proofs! Also, I can't get \in to work. Sorry about that!
All that you have shown thus far is that if [itex]x \in S_1[/itex] and [itex]y \in S_2[/itex], then [itex]x + y \leq lub(S_1) + lub(S_2)[/itex].
This implies that [itex]lub(x + y : x\in S_1, y\in S_2) \leq lub(S_1) + lub(S_2)[/itex].
However, you still have to prove the opposite inequality.
Wait, sorry if I don't understand. Are you saying I have to prove the inequality when instead of it being ≤, I prove ≥?
Yes. If your goal is to prove that A = B, and you have only proved A <= B, then you also need to show that A >= B before you can conclude that A = B.
...oh. WELL, excuse me while I think about this some more and get back to you. Haha.
So let me get this straight. I now have to prove that x ≥ a in S1 and y ≥ b in S2. BUT, isn't that a contradiction? If you add them, you get x+y≥a+b, but if the elements of x, y in their respective sets are greater than the l.u.b., then a and b are not the l.u.b.
I don't quite understand. Perhaps you can guide me in the right direction. Much thanks.
-J
-J
No, you have to show that [itex]lub(x + y : x \in S_1, y \in S_2) \geq lub(S_1) + lub(S_2)[/itex]
I'm going to introduce some shorthand so it's easier to type:
a = lub(S_1)
b = lub(S_2)
c = lub(x+y : x in S_1, y in S_2)
If there were specific elements x in S_1 and y in S_2 such that x + y >= a + b, then you'd be done, because x + y <= c. But there might not be such elements. In fact, if there were, then you would have x = a and y = b. Thus each of the two sets S_1 and S_2 would contain its supremum. This is not guaranteed.
However, if you let [itex]\epsilon > 0[/itex], can you find x in S_1 and y in S_2 such that [itex]x > a - \epsilon[/itex] and [itex]y > b - \epsilon[/itex]? i.e. you might not be able to find elements that achieve the upper bound, but can you get them arbitrarily close? If so, what can you do with that?
Related to Real Analysis Least Upper Bound Question
What is the definition of a least upper bound?
A least upper bound, also known as a supremum, is the smallest number that is greater than or equal to all the elements in a set. In other words, it is the smallest upper bound for a set of numbers.
How is the least upper bound used in real analysis?
In real analysis, the least upper bound plays a crucial role in proving the existence of a limit, continuity, and differentiability of functions. It also helps in defining the completeness of a set of numbers and the convergence of sequences and series.
Does every set of real numbers have a least upper bound?
No, not every set of real numbers has a least upper bound. For example, the set of all negative real numbers does not have a least upper bound. A set must be bounded above to have a least upper bound.
What is the difference between a least upper bound and a maximum?
A least upper bound is the smallest number that is greater than or equal to all elements in a set, while a maximum is the largest number in a set. A set may have a maximum but not a least upper bound, or it may have both a maximum and a least upper bound.
How do you find the least upper bound of a set of numbers?
To find the least upper bound of a set of numbers, you can use a few different methods such as the completeness axiom, the monotone convergence theorem, or the Bolzano-Weierstrass theorem. These methods involve examining the properties of the set and its elements to determine the smallest upper bound.
