Real analysis, sequence of sequences convergence proof
Perelman
\ell is the set of sequences of real numbers where only a finite number of terms is non-zero, and the distance metric is d(x,y) = sup|x_n - y_n|, for all n in naural-numbers
then the sequence u_k = {1,\frac{1}{2},\frac{1}{3},...,\frac{1}{k}, 0,0,0...}
and \left\{u_k\right\}^{\infty}_{k=1} is what i assume to be a sequence of sequences.
I know its a Cauchy sequence. the question ask to show that {uk} is convergent or not convergent
so here i just see that it will converge to the sequence \frac{1}{k} from k=1 to infinity which converges to 0 but doesn't contain finite non-zero numbers. so the squenec doest belong to the set \ell and its not convergent in \ell
Is this correct or completely wrong. I have a feeling its not and it needs more epsilons. Hard thing with proof is that there is no way to check my answer. if its correct i have some follow-up questions
Likes Ray Vickson
Yes, that's correct. The sequence is Cauchy but the limit isn't in \ell.
oh nice, okay the follow up. there is a set c0 that is the set of all sequences that converges to zero. then prove that \ell is dense in c0.
so if I am not mistaken dense means that \ell must belong in c0 and all the limits of \ell must also be in c0
Let u_n be a sequence in \ell, since it only have a finite non-zero numbers then for some n\ge N , d(x_n, 0)< \epsilon and it have limit 0. also All the limits of \ell must stay inside c_0, so i must show that it can't converge to a squence that doest converge to 0, here I am not sure how to prove this. and i tested with the squenec that convrege to {1,1,1,1...} the same way as u_k converge to 1/k but this one is not cauchy thefore its not a limit. maybe i can show that more general in some way.
I don't think you are trying to prove the right thing. is dense in if for every element in there is a sequence of elements of that converge to .
Dick said:
I don't think you are trying to prove the right thing. ##\ell## is dense in ##c_0## if for every element ##c## in ##c_0## there is a sequence of elements of ##\ell## that converge to ##c##.
but from this http://mathworld.wolfram.com/Dense.html
A set
in a first-countable space is dense in
if
, where
is the set of limit points of
so some sequence in c0 must be in \ell or in the limit of \ell rigth?
so by showing that all \ell sequences converges to 0 or that all seq in c0 will eventually have infinite 0,0,0... elements then its in \ell.
but then i also must show that all the limits of \ell must be in c0 like my problem above states, and I am not sure how to do.. or am i thinking wrongly?
A set
if [PLAIN]http://mathworld.wolfram.com/images/equations/Dense/Inline3.gif, where http://mathworld.wolfram.com/images/equations/Dense/Inline4.gif is the set of limit points of
First show every element of is the limit of a convergent sequence in . That should be pretty easy. To prove every Cauchy sequence in converges to an element of prove it by contradiction. Suppose it converges to a sequence which does not converge to zero. Try to find a contradiction.
Dick said:
First show every element of ##c_0## is the limit of a convergent sequence in ##\ell##. That should be pretty easy. To prove every Cauchy sequence in ##\ell## converges to an element of ##c_0## prove it by contradiction. Suppose it converges to a sequence which does not converge to zero. Try to find a contradiction.
ye that's wat i was thinking and said in above post more or less. but I am stuck I am not that proficient in this and have tried. was thinking that the sequence that converges to some sequence that doesn't converge. like the and k=1 to infinity. but with just k instead of 1/k so that it will "converge" to the sequence {k,k,k,k,k...} and the sequence that "convereges" to this is not cauchy so it can't converege to it. but this is probably not general enough. can you help me a bit further in right direction.
Perelman said:
ye that's wat i was thinking and said in above post more or less. but I am stuck I am not that proficient in this and have tried. was thinking that the sequence that converges to some sequence that doesn't converge. like the ##u_k## and k=1 to infinity. but with just k instead of 1/k so that it will "converge" to the sequence {k,k,k,k,k...} and the sequence that "convereges" to this is not cauchy so it can't converege to it. but this is probably not general enough. can you help me a bit further in right direction.
Sure. A single example isn't a proof. If a sequence doesn't converge to zero what can you say about it? Carefully negate the statement that it does converge to zero. And I'll repeat, "First show every element of is the limit of a convergent sequence in . That should be pretty easy." It's also the more important condition.
Dick said:
Sure. A single example isn't a proof. If a sequence doesn't converge to zero what can you say about it? Carefully negate the statement that it does converge to zero. And I'll repeat, "First show every element of ##c_0## is the limit of a convergent sequence in ##\ell##. That should be pretty easy." It's also the more important condition.
well negating the statement then i get
if a sequence doesn't converge to 0 then there exist some such that .
and then some contradiction happens i guess. but i can't see this.. especially if it supposed to be easy.
so i need to use the fact that its also a Cauchy sequence maybe. or that the sup of the difference of two sequences in will always be the max of a finite set of positive numbers.? i don't see anymore info about this set that can help me.
if a sequence doesn't converge to 0 then there exist some ##n>N## such that ##d(x_n, 0) > \epsilon##.
so i need to use the fact that its also a Cauchy sequence maybe. or that the sup of the difference of two sequences in ##\ell## will always be the max of a finite set of positive numbers.? i don't see anymore info about this set that can help me.
How to go forward would be clearer if you had negated the statement more carefully. The negation is "there exists such that for all there exists such that ". In other words there exists an infinite number of terms larger than . Think that would cause a problem for the Cauchy thing?
Dick said:
How to go forward would be clearer if you had negated the statement more carefully. The negation is "there exists ##\epsilon \gt 0## such that for all ##N \gt 0## there exists ##n \gt N## such that ##|x_n| > \epsilon##". In other words there exists an infinite number of terms larger than ##\epsilon##. Think that would cause a problem for the Cauchy thing?
ok so since its a Cauchy sequence at some point you have where is the sequence that's non-zero convergent, call it
then the where with infinite zeros and for k = 1 to infinity, the difference of that is the sequence, where d is the difference that could be zero or some real number, and u_k that is just the difference and all the infinite many zeros of the sequence and this must be a non-zero number.
so here the sup of this can never be zero. and this shows that a sequence in # can never converge to a non-zero-convergent sequence.
correct , or did you think of something else?
Perelman said:
ok so since its a Cauchy sequence at some point you have ##d(x_n, x_m) < \epsilon## where ##x_m## is the sequence that's non-zero convergent, call it ##u_k##
then the ##sup|x_n, u_k|## where ##x_n = {x_0, x_1, x_2...x_i, 0,0,0...}## with infinite zeros and ##u_k = {u_0, u_1...u_k}## for k = 1 to infinity, the difference of that is the sequence, ##{d_0, d_1...d_{i}, u_{i+1}...u_{k}}## where d is the difference ##x_n - u_k## that could be zero or some real number, and u_k that is just the difference ##u_k## and all the infinite many zeros of the ##x_n## sequence and this must be a non-zero number.
so here the sup of this can never be zero. and this shows that a sequence in ##\ell### can never converge to a non-zero-convergent sequence.
I'm not sure I quite follow that, but the point is that since you know the infinite sequence, call it , doesn't converge to zero, there are an infinite number of terms with absolute value greater than . Can you see why no sequence in can satisfy ?
Dick said:
I'm not sure I quite follow that, but the point is that since you know the infinite sequence, call it ##u##, doesn't converge to zero, there are an infinite number of terms with absolute value greater than ##\epsilon##. Can you see why no sequence ##x## in ##\ell## can satisfy ##d(u,x)<\epsilon##?
hmm what about this?
no sequenec x in can satisfy because there exist an N s.t for all , but , and then for all and must also be , making and this contradicts that it is a cauchy sequence.
no sequenec x in ##\ell## can satisfy ##d(u,x) < \epsilon## because there exist an N s.t for all ##n>N , d(x_n,0) < \epsilon##, but ##d(u_n,0) > \epsilon##, and then for all ##n>N, |u_n - x_n| > \epsilon## and ##sup|u - x|## must also be ##> \epsilon##, making ##d(x ,u) > \epsilon## and this contradicts that it is a cauchy sequence.
That's a bit of a muddle. Just relax and think more carefully about the quantifiers. Look at the negation of a sequence converging to zero I stated in post #10. Tell me how that implies that no sequence in can approximate better than . Just think about it for a while. Don't worry about the Cauchy bit, I dashed that hint off running out the door this morning. You don't need it.
Too help you think about it a sequence that doesn't converge to zero is a bit like the sequence . First prove that can't be a limit of sequences in , if that helps.
Dick said:
That's a bit of a muddle. Just relax and think more carefully about the quantifiers. Look at the negation of a sequence converging to zero I stated in post #10. Tell me how that implies that no sequence in ##\ell## can approximate ##u## better than ##\epsilon##. Just think about it for a while. Don't worry about the Cauchy bit, I dashed that hint off running out the door this morning. You don't need it.
Too help you think about it a sequence that doesn't converge to zero is a bit like the sequence ##(\epsilon, \epsilon, \epsilon, ...)##. First prove that can't be a limit of sequences in ##\ell##, if that helps.
but i think that's what i was trying to say in the last post
so that for all for some natural number N then
- the sequences will only now have infinite trailing zeros forever
- while will have something bigger than forever.
so when u are doing distance between those two sequences it can never be less than \epsilon since the metric takes the supremum of the difference. so that's the closest they can be.but maybe my understanding of the infinity thing is wrong like my assumption that for all , will just have zeros 0,0,0... forever. and that it will never have some non-zero numbers mixed in, since if those should be finite, then at some point it must stop and the zeros will continue on forever without anymore non-zero numbers. While the other sequence will still have numbers bigger than that.
is this wrong or is there is any other flaw in this, i was thinking i got it.
so that for all ##n>N## for some natural number N then
- the sequences ##x## will only now have infinite trailing zeros forever
- while ##u## will have something bigger than ##\epsilon## forever.
so when u are doing distance between those two sequences it can never be less than \epsilon since the metric takes the supremum of the difference. so that's the closest they can be.but maybe my understanding of the infinity thing is wrong like my assumption that for all ##n>N##, ##x## will just have zeros 0,0,0... forever. and that it will never have some non-zero numbers mixed in, since if those should be finite, then at some point it must stop and the zeros will continue on forever without anymore non-zero numbers. While the other sequence ##u## will still have numbers bigger than that.
You've got the right idea. I was just having a hard time interpreting your presentation. Now how about proving a sequence converging to zero is the limit of sequences in ?
Dick said:
You've got the right idea. I was just having a hard time interpreting your presentation. Now how about proving a sequence converging to zero is the limit of sequences in ##\ell##?
ye it gets a bit complicated with my notation when its sequence of sequences.
Dick said:
Now how about proving a sequence converging to zero is the limit of sequences in ℓ\ell?
well i proved that there can't be a sequence in that converge to a non-zero-limit sequence. so then all sequences in must converge to a zero-limit sequence. if I am not mistaken. so then that's already proved?
also
Let u be a sequence from the set , since it only have a finite non-zero numbers then there exist a N s.t for all , i.e
this shows that all sets from have zero-limit.
so now all sets from have zero limit or a sequences in will converge to a zero-limit-sequence. isn't this now a proof that is dense in
well i proved that there can't be a sequence in ##\ell## that converge to a non-zero-limit sequence. so then all sequences in ##\ell## must converge to a zero-limit sequence. if I am not mistaken. so then that's already proved?
also
Let u be a sequence from the set ##\ell##, since it only have a finite non-zero numbers then there exist a N s.t for all ##n>N##, ##d(x_n,0)<\epsilon## i.e ##lim(u)=0##
this shows that all sets from ##\ell## have zero-limit.
so now all sets from ##\ell## have zero limit or a sequences in ##\ell## will converge to a zero-limit-sequence. isn't this now a proof that ##\ell## is dense in ##c_o##
You've shown that for every sequence in that has a limit that that limit must be in . That doesn't show that every element of is a limit of a sequence in . Pick an arbitrary element of and think how you might construct a sequence in that will converge to it. I'll repeat that I think this is the most important part of the proof. It's really what 'dense' is about.
Dick said:
You've shown that for every sequence in ##\ell## that has a limit that that limit must be in ##c_0##. That doesn't show that every element of ##c_0## is a limit of a sequence in ##\ell##. Pick an arbitrary element of ##c_0## and think how you might construct a sequence in ##\ell## that will converge to it. I'll repeat that I think this is the most important part of the proof. It's really what 'dense' is about.
Dick said:
Pick an arbitrary element of c0c_0 and think how you might construct a sequence in ℓ\ell that will converge to it.
it seems like you know some standard way of doing these things, i have no idea how to really construct such a sequence.
Start with a concrete example, take the infinite series (1,1/2,1/3,1/4,...) in . Can you think of a sequence in that would work?
Dick said:
Start with a concrete example, take the infinite series (1,1/2,1/3,1/4,...) in ##c_0##. Can you think of a sequence in ##\ell## that would work?
yea the sequence from post #1 would work for that concrete example
Doesn't that give you some idea of what to do in general?
i don't get it since if I am not mistaken then there is lots of more sequences that converges to zero, and the sequence in L that converges to it would probably not look like post #1 sequence at all. i might have some holes in my understanding of this so don't hesitate by giving me details that you might think i already know
Are you sure that the 0-sequence does not belong to ? Since 0 is a finite number it is certainly true that for the 0-sequence, "all but a finite number of terms is nonzero", where here we have 0 nonzero terms. Perhaps this is defined/clarified somewhere in your textbook or notes, or perhaps you were told explicitly to not regard the 0-sequence as an element of . That would be useful to know.
Ray Vickson said:
Are you sure that the 0-sequence does not belong to ##\ell##? Since 0 is a finite number it is certainly true that for the 0-sequence, "all but a finite number of terms is nonzero", where here we have 0 nonzero terms. Perhaps this is defined/clarified somewhere in your textbook or notes, or perhaps you were told explicitly to not regard the 0-sequence as an element of ##\ell##. That would be useful to know.
i can't find anything about it so maybe zero sequence could be part of it.
Hmm. Suggest a sequence from that might converge to (1,1/2,1/4,1/8,1/16,...).
Dick said:
Hmm. Suggest a sequence from ##\ell## that might converge to (1,1/2,1/4,1/8,1/16,...).
well if
then the sequence from k=0 to infinity will converge to that ?
Perelman said:
well if ##u_k = (1/2^0, 1/2^1 , 1/2^2 , 1/2^3, 1/2^4 ... 1/2^k...0,0,0, ... )##
then the sequence ##u_k## from k=0 to infinity will converge to that ?
Perfect. You still don't see what to do with a general sequence that converges to zero? Take .
Dick said:
Perfect. You still don't see what to do with a general sequence that converges to zero? Take ##(a_1,a_2,a_3,...)##.
i still don't see it. what properties does this sequence (a1,a2,a3...) have ? is it like a special kind of general structure of all these zero convergent sequences. Because i don't see anything general about those two concrete examples you gave me or how they are relevant. I'm sure there are more zeorconvergen sequences that is not on the form 1/k^n somthing , . i would think a zeroconvergence sequence could be anything, only thing that's special about it is that it gets closed to zero
Hmm. Ok, , a sequence that converges to 0. How about if you define ? What is the limit of the sequence ?
  • #31
Dick said:
Hmm. Ok, ##a=(a_1,a_2,a_3,...)##, a sequence that converges to 0. How about if you define ##u_k=(a_1,a_2,...,a_k,0,0,0,...)##? What is the limit of the sequence ##u_k##?
it will converges to , i think i found some kind of proof now.
let be a zeroconvergent sequence.
then for all , for some then
let be and be s.t
then the sequence of sequences for k=1 to infinity in would converge to
because which all the elements up to and including turns zero and you end up with the supremum of the difference, must be the supremum, since its a decreasing sequence.
since is the of the sequence , and then
. for all
  • #32
Perelman said:
it will converges to ##a##, i think i found some kind of proof now.
let ##a = (a_1,a_2,a_3,a_k..)## be a zeroconvergent sequence.
then for all ##n,m > N , d(a_n, a_m)<\epsilon##, for some ##N## then
let ##n## be ##n+1## and ##m## be ##n+a## s.t ##d(a_{n+1}, a_{n+a})<\epsilon.##
then the sequence of sequences ##L = (a_1,a_2,...,a_k,0,0,0,...)## for k=1 to infinity in ##\ell## would converge to ##a##
because ##d(L_n , L_{n+a}) = sup|L_n - L_{n+a}|## which all the elements up to and including ##L_n## turns zero and you end up with the supremum of the difference, ##L_{n+1}## must be the supremum, since its a decreasing sequence.
since ##L_{n+1}## is the ##a_{n+1}## of the sequence ##a##, and ## L_{n+a} = a_{n+a} ## then
##d(L_{n+1} , L_{n+a}) < \epsilon##. for all ##n>N##
It doesn't say that the sequence is decreasing, it just says that it converges to zero. I think you've got the right idea but your notation is pretty confusing. If you want to set then you want to prove that the sequence converges to . So for all there exists an such that for all that . Can you try to state a proof of that a bit more clearly?
  • #33
Dick said:
It doesn't say that the sequence ##a## is decreasing, it just says that it converges to zero. I think you've got the right idea but your notation is pretty confusing. If you want to set ##L_k = (a_1,a_2,...,a_k,0,0,0,...)## then you want to prove that the sequence ##(L_1,L_2,L_3,...)## converges to ##a##. So for all ##\epsilon \gt 0## there exists an ##N## such that for all ##n \gt N## that ##d(L_n,a) \lt \epsilon##. Can you try to state a proof of that a bit more clearly?
let be a zero-convergent sequence.
then the sequence of sequences for n=1 to infinity in would converge to
because , all the elements up to and including turns to zero, therfor
since for all for some N then
, for all for some N
  • #34
Perelman said:
let ##a = (a_1,a_2,a_3,a_k..)## be a zero-convergent sequence.
then the sequence of sequences ##L_n = (a_1,a_2,...,a_n,0,0,0,...)## for n=1 to infinity in ##\ell## would converge to ##a##
because ##d(L_n , a) = sup|L_n - a|##, all the elements up to and including ##a_n## turns to zero, therfor ##d(L_n , a) = sup|(a_{n+1}, a_{n+2}...)|##
since for all ##n>N, d(a_n,0) < \epsilon## for some N then
##d(L_n , a) = sup|(a_{n+1}, a_{n+2}...)| < \epsilon## , for all ##n>N## for some N
Better. You should mention why there exists such an N. It's because converges to zero, right? Spelling out more reasons makes for a more readable proof.
  • #35
Dick said:
Better. You should mention why there exists such an N. It's because ##a## converges to zero, right? Spelling out more reasons makes for a more readable proof.
okay ill add that in in my paper. but is this the whole proof or do i also need the other things? since now could just be a boundary around but i guess that's also counted as being dense. maybe i also need to add proof that
  • #36
Perelman said:
okay ill add that in in my paper. but is this the whole proof or do i also need the other things? since now ##c_0## could just be a boundary around ##\ell## but i guess that's also counted as ##\ell## being dense. maybe i also need to add proof that ##\ell \subset c_0##
I think you've done all you need to do. But if you aren't convinced of that you should do more to convince yourself.
  • #37
but i mean we did three things
everything from is in
all seqeunce in converger in
and all "points" in has a seqeunce in that converge to it
so its all those together right?. also thanks a lot for your help :)
  • #38
Sort of, we didn't prove all sequences in converge. We proved that if a sequence in converges, then it converges to a limit in . You're welcome!
