Real integral=area , complex integral= ?
In summary, a complex integral can be used to evaluate integrals that would otherwise be difficult or impossible to evaluate.
dyn
773
61
Hi. If a real integral between 2 values gives the area under that curve between those 2 values what does a complex integral give between 2 values ?
Well, we can write a complex integral as
## \int(u+iv)(dx+idy) = \int(udx-vdy)+i\int(vdx+udy)##.
Now define a couple of forces, ## \mathbf{F}_1 = (u,-v) ##, ## \mathbf{F}_2 = (v, u) ##, and an infinitesimal displacement ## d\mathbf{r} = (dx,dy) ##. Then the complex integral is the same as
## \int \mathbf{F}_1\cdot d\mathbf{r} + i \int \mathbf{F}_2\cdot d\mathbf{r} ##. That is, it's a complex number, the real part of which is the work done by ## \mathbf{F}_1 ## and the imaginary part of which is that done by ## \mathbf{F}_2 ##.
Likes dyn
Thanks. That makes sense. So the complex integral has no relation to any geometric objects such as area ? Or no analogy with the real integral case ?
Your use of complex integrals will usually be with line integrals of functions that are analytic (have complex derivatives). That is a whole new ball game. The existence of the complex derivative has surprising consequences. All closed integrals of a function that is analytic in the enclosed area has the value 0.
real integrals are not just area. integration is a process that gives a different answer for every input. the integral of height is area, the integral of velocity is displacement, the integral of density is mass, etc... read the elements of calculus by michael comenetz for a better explanation.
complex path integrals are more like winding numbers. i.e. read the residue theorem. and relate it to the integral of dtheta.
It is a path integration over the complex plane, as said before it play a central rule in complex analysis, is some sense is a generalization of classical Riemann integral. The principal application is with the Residue Theorem. It is possible to evaluate a lot of real definite integrals that are not obvious with classical methods of integration, passing through a complex integration ...
Related to Real integral=area , complex integral= ?
1. What is the difference between a real integral and a complex integral?
A real integral is a mathematical concept that represents the area under a real-valued function on a specific interval. It is often used to calculate physical quantities such as distance, velocity, and acceleration. On the other hand, a complex integral is an extension of real integrals to complex-valued functions. It is used to calculate complex quantities such as electric fields, fluid flow, and quantum mechanics.
2. How is a real integral calculated?
A real integral is typically calculated using the Fundamental Theorem of Calculus, which states that the integral of a function can be found by evaluating its antiderivative at the upper and lower limits of integration. This process is known as the definite integral. The integral of a function can also be approximated using numerical methods such as the trapezoidal rule or Simpson's rule.
3. Can complex integrals be graphed like real integrals?
No, complex integrals cannot be graphed in the same way as real integrals. This is because the values of complex integrals are represented in the complex plane, which has both real and imaginary axes. However, certain properties of complex integrals can be visualized using contour plots or vector fields.
4. What are some practical applications of complex integrals?
Complex integrals have a wide range of applications in physics, engineering, and mathematics. They are used to calculate quantities such as electromagnetic fields, fluid flow, and probability distributions. In engineering, complex integrals are used in circuit analysis, signal processing, and control systems. In mathematics, complex integrals are used in the study of complex functions and their properties.
5. Are there any limitations to using complex integrals?
One limitation of complex integrals is that they can only be applied to functions that are analytic, meaning they can be represented by a power series. This excludes functions with singularities or discontinuities. Additionally, complex integrals can be challenging to calculate for highly complex functions, and numerical methods may be necessary. Furthermore, interpreting and visualizing complex integrals can be difficult due to the nature of the complex plane.
  • Calculus
