Real Numbers Inequality Proof: x+y+z > (|x|+|y|+|z|)/3
  • MHB
  • Thread starter anemone
  • Tags
    2015
In summary, the purpose of a real numbers inequality proof is to demonstrate the truth of a mathematical statement for all real numbers. This is achieved through logical reasoning and mathematical operations. To approach such a proof, one should clearly state the given inequality and use algebraic manipulations and properties of real numbers to simplify the expression. The absolute value in the inequality proof formula is significant as it ensures the validity of the proof for both positive and negative values of the variables. Any real numbers can be used for the variables in the proof, as the properties of real numbers hold true for all values. Some helpful strategies for solving real numbers inequality proofs include using properties of inequalities, breaking down complex expressions, and considering special cases or examples. It is also important to
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Suppose $x,\,y,\,z$ are real numbers such that $x+y>0$, $y+z>0$ and $z+x>0$.
Prove that $x+y+z>\dfrac{|x|+|y|+|z|}{3}$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solutions::)
1. lfdahl
2. greg1313
Solution from greg1313:
If x > 0, y > 0, z > 0 we are done.
From the given inequalities only one of x, y, z can be non-positive and by symmetry this can be anyone of x, y, z; the outcome will be the same.
Choosing y to be non-positive, we also have |x| > |y| and |z| > |y|.
Now, with y non-positive
\(\displaystyle x + y + z = |x| - |y| + |z| = \frac{3|x|-3|y|+3|z|}{3}\)
If the difference \(\displaystyle \frac{3|x|-3|y|+3|z|}{3}-\frac{|x|+|y|+|z|}{3}\) is positive we are done.
\(\displaystyle \frac{3|x|-3|y|+3|z|}{3}-\frac{|x|+|y|+|z|}{3}=\frac{2(|x|+|z|)-4|y|}{3}\)
but since |x| > |y| and |z| > |y|, |x| + |z| > 2|y| so \(\displaystyle \frac{2(|x|+|z|)-4|y|}{3}>0\) as required.
FAQ: Real Numbers Inequality Proof: x+y+z > (|x|+|y|+|z|)/3
What is the purpose of a real numbers inequality proof?
The purpose of a real numbers inequality proof is to show that a mathematical statement is true for all real numbers. This is done by using logical reasoning and mathematical operations to demonstrate that the statement is always greater than or equal to the other side of the inequality.
How do you approach a real numbers inequality proof?
To approach a real numbers inequality proof, you should start by clearly stating the given inequality and any other relevant information. Then, use algebraic manipulations and properties of real numbers to simplify the expression and eventually reach the desired inequality. It is important to justify each step with mathematical reasoning to ensure the validity of the proof.
What is the significance of the absolute value in the inequality proof formula?
The absolute value in the inequality proof formula ensures that the proof holds true for both positive and negative values of the variables. This is because the absolute value of a number is its distance from zero on the number line, so it will always be positive regardless of the sign of the number.
Can you use any real numbers for the variables in the inequality proof?
Yes, you can use any real numbers for the variables in the inequality proof. This is because the properties of real numbers hold true for all real numbers, so the proof will be valid for any values of the variables.
Are there any specific strategies or techniques for solving real numbers inequality proofs?
There are several strategies and techniques that can be helpful when solving real numbers inequality proofs. These include using properties of inequalities, breaking down complex expressions into smaller parts, and considering special cases or examples to support your reasoning. It is also important to check your work and ensure that your proof is valid for all real numbers.
