MHB Real solution of the equation {x} = {x²} = {x³}
  • Thread starter Thread starter juantheron
The equation {x} = {x²} = {x³} leads to the conclusion that {x} can be expressed as k, where k is a real number between 0 and 1. By defining x as i + f, where i is an integer and 0 ≤ f < 1, the equation simplifies to f = 2if + f², yielding solutions when f = 0 or f = 1 - 2i. The discussion highlights that integer solutions exist, but also emphasizes the presence of many non-integer solutions. A significant non-integer solution identified is the golden ratio, approximately 1.618, which arises from the quadratic equation x² - x - 1 = 0. Overall, the exploration reveals a variety of solutions, both integer and non-integer, for the original equation.
juantheron
Find all real solution of the equation $\{x\} = \{x^2\} = \{x^3\}$.
My Try:
Let $\{x\} = \{x^2\} = \{x^3\} = k\;,$ where $k\in \mathbb{R}$ and $0\leq k<1$
Now we can write it as $x-\lfloor x \rfloor = x^2-\lfloor x^2 \rfloor = x^3-\lfloor x^2 \rfloor = k$
Now I did not Understand How can i proceed further.
Help me for solving above Question.
Thanks
Mathematics news on Phys.org
Re: Real solution of the equation $\{x\} = \{x^2\} = \{x^3\}$
My Try:
Thanks
Let's define $x=i+f$ where $i$ is an integer and $0 \le f < 1$.
Then:
$$\{x\} = \{x^2\}$$
$$f = 2if + f^2$$
$$f^2 + f(2i-1) = 0$$
$$f = 0 \vee f = 1-2i$$
In other words, the only solutions occur when the fraction is 0.
... and all integers are solutions.
Then:
$$\{x\} = \{x^2\}$$
$$f = 2if + f^2$$
$\{x\} = \{x^2\}$ does not imply that $f^2 + f(2i-1) = 0$. I don't have suggestions at the moment, but there are many non-integer solutions.
[GRAPH]3eklechsml[/GRAPH]
Ah. You're right.
I see my mistake - it's right in my first step.
A proper solution for $\{x\}=\{x^2\}$ follows from $1+x=x^2 \Rightarrow x^2-x-1=0 \Rightarrow x=\frac 1 2 (\sqrt 5 + 1) \approx 1.618$.
It's the golden number!
It seems that $x^2=x+k$ for all $k\in\Bbb Z$ determines a solution of $\{x^2\}=\{x\}$, and solutions for $k=1,3,4,5,7,8,9,10,11,13,\dots$ are non-integer.
$x^2 = x + k$
then $k = x^2-x = x(x-1)$
so k can take all values and if it is n of the form n(n-1) then it is non - integer. n(n-1) shall give integers
as $n(n-1) + n = n^2$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
