Real Solutions for Equation: a-1
  • MHB
  • Thread starter anemone
In summary, we found all real solutions of the equation by substituting $b = \sqrt{a-1}$ and multiplying through by $a^2b^2$. This resulted in a factorization of $(b+a)(b-a)(a^2-b)(b-1) = 0$. Since the first factor cannot be zero and the remaining factors do not yield real solutions, the only solution to the equation is $a=2$. This method eliminates the need for any root analyses.
anemone
MHB
POTW Director
3,883
115
Find all real solutions of the equation $\sqrt{a-1}+\dfrac{\sqrt{a-1}}{a^2}+\dfrac{a^2}{a-1}=\dfrac{1}{\sqrt{a-1}}+\dfrac{a-1}{a^2}+\dfrac{a^2}{\sqrt{a-1}}$.
Mathematics news on Phys.org
[sp]Let $b = \sqrt{a-1}$. Then $b + \dfrac b{a^2} + \dfrac{a^2}{b^2} = \dfrac1b + \dfrac{b^2}{a^2} + \dfrac{a^2}b.$ Also, $b^2 = a-1$, $b>0$ (assuming that we take the square root to be the positive one) and $a>1$ (so that the square root is defined). Multiply through by $a^2b^2$ to get $$a^2b^3 + b^3 + a^4 = a^2b + b^4 + a^4b.$$ Write this as $$b(b^2-a^2) + a^2b(b^2-a^2) - (b^4 - a^4) = 0.$$ That factorises as $(b^2-a^2)(b + a^2b - a^2-b^2) = 0$, and then factorises further as $(b+a)(b-a)(a^2-b)(b-1) = 0.$ The first factor cannot be zero because $a$ and $b$ are both positive. If $b=a$ then the equation $b^2=a-1$ becomes $a^2-a+1=0$, which has no real solutions. Similarly if $b=a^2$ then we get the equation $a^4-a+1=0$, which also has no real solutions. Finally, if $b=1$ then $a=2$, and that is the only solution to the problem.[/sp]
Let:
\(\displaystyle 0<u^2=a-1\)
After making the substitution and multiplying the result by \(\displaystyle u^2\left(u^2+1 \right)^2\) we obtain:
\(\displaystyle u^3\left(u^2+1 \right)^2+u^3+\left(u^2+1 \right)^4=u\left(u^2+1 \right)^2+u^4+u\left(u^2+1 \right)^4\)
which can be arranged and factored as:
\(\displaystyle (u-1)\left(u^6+2u^4+2u^2-u+1 \right)\)
Regarding the sextic factor (let's call if $f$), let's look at its derivative:
\(\displaystyle f'(u)=6u^5+8u^3+4u-1\)
Descartes' Rule of Signs tells us there is at most 1 positive real root. We should observe that it will be close to zero. Use of a numeric root finding technique puts this root at about:
\(\displaystyle u\approx0.22602207985644908028\)
We can see that the second derivative will be positive for all real $u$, hence this critical value is at a global minimum. We then find:
\(\displaystyle f_{\min}\approx f(0.22602207985644908028)\approx0.881502759171198736472582>0\)
Hence, we may conclude $f$ has no real roots, and so $u=1$ is the only root, which means:
\(\displaystyle a-1=1^2\implies a=2\)
is the only real root of the given equation.
Thank you Opalg for participating! I initially thought to share the solution of other that I considered to be a brilliant way to attack this problem but now I see there is no need to do so...:eek:
MarkFL said:
Let:
Hey MarkFL, my dearest and sweetest admin, I like your method so much as well! I think this is another great method to crack this problem! Thanks for your solution!(Sun)
Hey MarkFL,:) I see there is another way to prove the second factor in \(\displaystyle (u-1)\left(u^6+2u^4+2u^2-u+1 \right)\) so that it is always greater than zero:
\(\displaystyle (u-1)\left(u^6+2u^4+2u^2-u+1 \right)=0\)
$\begin{align*}u^6+2u^4+2u^2-u+1&=(u^6+2u^4+u^2)+(u^2-u+1)\\&=u^2(u^4+2u^2+1)+\left(u-\dfrac{1}{2} \right)^2+1-\dfrac{1}{4}\\&=u^2(u^2+1)^2+\left(u-\dfrac{1}{2} \right)^2+\dfrac{3}{4}\\& >0 \end{align*}$
Quite clever, and alleviates the need for any root analyses. (Yes)
FAQ: Real Solutions for Equation: a-1
What is the definition of a "real solution" for an equation?
A real solution for an equation is a value or set of values that, when substituted into the equation, make it true. In other words, it is the value(s) that satisfy the equation.
How do you solve an equation with a-1 as the variable?
To solve an equation with a-1 as the variable, you can use algebraic techniques such as combining like terms, isolating the variable, and using inverse operations to solve for a-1. You can also use a graphing calculator to visually find the real solutions.
Can there be more than one real solution for an equation with a-1?
Yes, there can be more than one real solution for an equation with a-1. This means that there can be multiple values of a-1 that satisfy the equation and make it true.
How do you check if a value is a real solution for an equation with a-1?
To check if a value is a real solution for an equation with a-1, simply substitute the value into the equation and see if it makes the equation true. If it does, then it is a real solution.
Are there any specific rules or guidelines for finding real solutions for equations with a-1?
There are no specific rules or guidelines for finding real solutions for equations with a-1. However, it is important to follow the order of operations and perform the same operations on both sides of the equation to maintain equality. It is also helpful to check your solutions by substituting them back into the original equation.
