MHB Real Solutions to $a-b+c-d=0; ab=cd; a^2-b^2+c^2-d^2=-24;a^2+b^2+c^2+d^2=50$
  • Thread starter Thread starter anemone
The discussion focuses on finding real solutions to a system of equations involving variables a, b, c, and d. Key equations include a-b+c-d=0, ab=cd, and a^2+b^2+c^2+d^2=50, among others. A participant highlights the importance of correctly applying the square root principle, noting that both a+b=c+d and a+b=-(c+d) must be considered, but only one is valid for this specific case. Another participant confirms they checked both scenarios and eliminated the incorrect one. The conversation emphasizes the analytical approach to solving complex algebraic equations.
anemone
MHB
POTW Director
Find all real solutions to the system
$a-b+c-d=0$
$ab=cd$
$a^2-b^2+c^2-d^2=-24$
$a^2+b^2+c^2+d^2=50$
Mathematics news on Phys.org
We are given
a- b + c - d = 0 ... (1)
ab = cd ...(2)
$a^2 - b^2 + c^2 - d^2 = - 24$ ...(3)
$ a^2 + b^2 + c^2 + d^2 = 50 $...(4)
from (1)
a- b = d- c... (5)
square above and using (2)
$(a-b)^2 + 4ab = (c-d)^2 + 4cd$
or $(a+b)^2 = (c+d)^2$
so $a + b = c + d$ ... (6)
or $a+ b = -c - d$ ..(7)
from (5) and (6) a = d and b= c but it is not possible as LHS of (3) is zero which is contradiction
from (5) and (7) a = -c and b = - d
so we get from (3) and (4)
$a^2 - b^2 = - 12$
$a^2 + b^2 = 25$
add above to get $2 a^2 = 13$, subtract to get $2b^2 = 37$
this gives 4 set of solutions
(a,b,c,d) = $(\sqrt\frac{13}{2},\sqrt\frac{37}{2},-\sqrt\frac{13}{2},-\sqrt\frac{37}{2})$
or $(\sqrt\frac{13}{2},-\sqrt\frac{37}{2},-\sqrt\frac{13}{2},\sqrt\frac{37}{2})$
or $(-\sqrt\frac{13}{2},-\sqrt\frac{37}{2},\sqrt\frac{13}{2},\sqrt\frac{37}{2})$
or $(-\sqrt\frac{13}{2},\sqrt\frac{37}{2},\sqrt\frac{13}{2},-\sqrt\frac{37}{2})$
kaliprasad said:
We are given
ab = cd ...(2)
from (1)
a- b = d- c... (5)
$a^2 - b^2 = - 12$
$a^2 + b^2 = 25$
Nice solution!(Cool)(Sun) I especially like how you observed if $(a+b)^2 = (c+d)^2$, then both $a+b=c+d$ or $a+b=-(c+d)$ hold true for general case but then we need to choose wisely which one only works for our case . I mean, we all know we should put the plus minus sign when taking square root, but it seems so brilliant to apply it in question such as this one, and I learned quite a bit from you, kali!
Thanks anemone, I checked for both cases and saw that one works and another does not. so I removed the erroneous case.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
