lfdahl
MHB
- 749
Find all real solutions to the equation:
$x^4+y^4+z^4 = 4xyz-1$.
[sp]lfdahl said:Find all real solutions to the equation:
Opalg said:[sp]
Write the equation as $x^4+y^4+z^4 + 1 = 4xyz.$ The left side is positive, so either all three of $x,y,z$ are positive or one of them is positive and the other two are negative. If there is a solution with only one of them positive, then by changing the signs of the other two we get a solution with all three variables positive. Therefore it is enough in the first place to look for solutions where $x,y,z$ are all positive. Then, using the AM-GM inequality, we get $$4xyz = 4\frac{x^4+y^4+z^4 + 1}4 \geqslant 4\sqrt[4]{x^4y^4z^41^4} = 4xyz,$$ with equality only if $x=y=z=1$. Therefore that is the only positive solution. The only other solutions are obtained be changing the signs of two of the variables.
Thus there are altogether four solutions, namely $(x,y,z) = (1,1,1),\ (1,-1,-1),\ (-1,1,-1),\ (-1,-1,1).$
[/sp]
When a problem or equation asks you to "find all real solutions", it means that you need to find all the possible values of the variable(s) that make the equation true. These values must be real numbers, meaning they can be positive, negative, or zero, and can include fractions or decimals.
To find all real solutions, you need to use mathematical techniques such as factoring, completing the square, or using the quadratic formula. These methods allow you to manipulate the equation and solve for the variable(s) in order to find all the real values that satisfy the equation.
Yes, an equation can have multiple real solutions. This means that there are multiple values of the variable that make the equation true. For example, the equation x^2 = 9 has two real solutions, x = 3 and x = -3.
If an equation has no real solutions, it means that there are no values of the variable that make the equation true. This can happen when the equation has a square root of a negative number or when the variable cancels out and the equation becomes a contradiction. In this case, the solution set is considered empty, or there are no real solutions.
There are a few general steps that can help when finding all real solutions. These include simplifying the equation, factoring if possible, setting each factor equal to zero and solving for the variable, and checking the solutions to make sure they work in the original equation. However, the exact steps may vary depending on the type of equation and the methods used to solve it.
