Really general question regarding basic Momentum
  • Thread starter Thread starter AJKing
    General Momentum
The discussion clarifies that the Law of Conservation of Momentum applies in isolated systems, particularly during collisions where external forces like friction are negligible. Momentum is conserved because the changes during a collision occur over an infinitesimally short time, allowing the assumption that external impulses are zero. In scenarios where two bodies collide in mid-air, momentum is conserved in all directions, while collisions involving fixed objects do not conserve momentum due to external impulses. The principle is mathematically represented by the equation m1u1 + m2u2 = m1v1 + m2v2, emphasizing that total momentum before and after a collision remains the same when external forces are ignored. Understanding these concepts is crucial for accurately applying momentum conservation in physics problems.
AJKing
My instruction material keeps talking about how "The Law of Conservation of Momentum" is only applicable in isolated systems, without friction or other dissipative forces.
However, in the same breath it will go on to say that Momentum is always conserved in collisions.
Would someone mind describing this in a little more depth?
And, while I'll surely read any materials you link me to on the matter, my entire course is sans human contact, so communicating would be rad :).
momentum is always conserved in collisions. we do not consider dissipative forces here only because when we calculate speed or velocity to compute momentum we actually consider its value just before and just after collision. here friction does not come into play. if we do consider the speed before or after a time interval before or after collision and use it to compute the momentum to verify or use the conservation of momentum principle there should not be any frictional loss, such that the speed remains same until the collision takes place. that is why the term 'without friction' is used.
Hi AJKing! :smile:
AJKing said:
… Momentum is always conserved in collisions.
Yes, https://www.physicsforums.com/library.php?do=view_item&itemid=53"
(and https://www.physicsforums.com/library.php?do=view_item&itemid=313")
This is because "collision" is always understood to mean that the change can be assumed to happen in an infinitesimally short time, and so the https://www.physicsforums.com/library.php?do=view_item&itemid=75" by any ordinary force (such as friction or gravity) can be assumed to be zero.​
eg when two bodies collide in mid-air, there are no external impulses (and only one external force, that of gravity) … external to the two-body system, that is … so momentum in all directions (and also angular momentum) is conserved.
when one body hits a fixed object, and bounces off, or rotates around it, the impulse from the fixed object is external to the one-body system, so the momentum of the body is not conserved, although the angular momentum about the point of contact will be conserved, since the impulse has no moment about that point :wink:
tiny-tim said:
Hi AJKing! :smile:Yes, https://www.physicsforums.com/library.php?do=view_item&itemid=53"
Yeah , if external force is neglected then total momentum before collision is same as after the collision
m1u1+m2u2=m1v1+m2v2
Or p1=-p2
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 60 ·
  • · Replies 35 ·
