Really hard intergration problem\ take a look
In summary: The work done in climbing the entire chain is the sum of those integrals:\int_0^{10} (20+ .5x)dx+ \int_{10}^{40} (22.5+ (1/4)x)dx= \left(20x+ \frac{1}{4}x^2\right)\left(\frac{1}{2}\right)|_0^{10}+ \left(22.5x+ \frac{1}{8}x^2\right)|_{10}^{40}= (100+ 25)+ (900+ 100- 225)= 1225- 25= 1200 foot-pounds.In summary,
peter0516
Really hard intergration problem\! take a look
A 20-lb. monkey is attached to a 50-ft. chain that weighs 0.5 lb.
per (linear) foot. The other end of the chain is attached to the
40-ft.-high ceiling of the monkey's cage. Find the amount of work the
monkey does in climbing up her chain to the ceiling.
anwser is 1087.5 ft-lb
can you figure it out??
As the monkey climbs up the mass he has to pull up becomes greater and greater, because he now also needs to lift a piece of the chain. Let's call the height z. The chain is 10 ft longer than the height of the roof. So for the first 10 meters the monkey has to climb every foot he needs to lift an additional 0.5 lb. So what is the mass as a function of z for the first 10 ft?
After those first 10 ft the entire chain is suspended in the air. From hat point on for every ft he climbs the length of the chain between the ceiling and the "bend" of the chain becomes shorter. Whereas the amount of chain between the the monkey and the "bend" becomes longer. Again you can express m in terms of z, but this time for every ft he has to climb there won't be 0.5 lb added but less. Think about it this way if the monkey reaches the ceiling both pieces of the chain will be 25 ft long. Now try to find both mass functions, after that its a simple integration over z.
I certainly don't see anything difficult about it, except perhaps determining when there is part of the chain lying on the floor and when there is not. When the monkey is at height a ft., at which the chain just touches the floor, the total length of the chain will be 40+ a= 50 so a= 10. When the monkey is at height x, with x< 10, there will be x ft of chain hanging below the monkey so going up by distance dx require work of (20+ .5x)dx foot-pounds. The work done climbing to that point is
[tex]\int_0^{10} (20+ .5x)dx[/tex]
Once x> 10, there will be 40- x feet of chain above the monkey leaving 50-(40-x)= 10+ x feet below the monkey. Half of that hangs from the ceiling and half from the monkey so there will be 5+ (1/2)x feet of chain hanging from the monkey and so he will be supporting (5+ (1/2)x)(0.5) pounds of chain. Raising himself and that chain dx feet will require work of (20+ 0.5(5+ 1/2)x))dx= (22.5+ (1/4)x)dx foot-pounds. The work done climbing from 10 feet above the ground to the ceiling is
[tex]\int_{10}^{40} (22.5+ (1/4)x)dx[/tex]
Related to Really hard intergration problem\ take a look
1. What is an integration problem?
An integration problem is a mathematical question that involves finding the integral of a function. This involves finding the area under a curve or the accumulation of a quantity over a given interval.
2. Why are integration problems considered difficult?
Integration problems can be difficult because they often require advanced mathematical knowledge and techniques to solve. They can also involve complicated equations and require a deep understanding of the concepts involved.
3. How do you approach a really hard integration problem?
The best approach for solving a difficult integration problem is to start with the basics and work your way through the problem step by step. This may involve using different integration techniques or breaking the problem down into smaller, more manageable parts.
4. What are some common techniques used to solve tough integration problems?
Some common techniques for solving challenging integration problems include substitution, integration by parts, and trigonometric substitution. It is important to have a strong understanding of each technique and when to use them in order to successfully solve the problem.
5. Are there any tips for improving my ability to solve hard integration problems?
Practice is key when it comes to improving your ability to solve difficult integration problems. It is also helpful to have a strong understanding of basic calculus concepts and techniques, as well as regularly reviewing and practicing with challenging integration problems.
14K
