Rearrangement of a complex radiation formula
In summary: So 1 R = 0.877 x 2.58 x 10-4 Gy = 2.25 x 10-4 Gy. And 1 mCi = 3.7 x 107 Bq. So G = 3.3 x 2.25 x 10-4 / (3.7 x 107) = 2.01 x 10-11 Bq-cm2/hr-mCi. So your formula would be A = 4.95 x 10-6 x 2.01 x 10-11 / (2.50 x 10-3) = 3.96 x 10-14 Bq.In summary, the conversation
murdrobe
30
6. If the exposure rate from 137Cs at one metre is 2.50 mGy/h, how many bequerels are present?
X=5.263 x 10-6 A∑(yiEi(μen/ρ)i)/r2
what I am looking to do isn't to solve the question, i need to rearrange the formula above so that A is the subject and i have no idea where to begin due to its complexity.
i would also like to know what the symbols represent, my interpretation from what i have found is that:
X = the exposure measured in Roetengens
A = The activity of the source measured in Bequerels
∑ = this sigma sign is equal to a complex value. To gather this number the individual energy of each photon that this radiation source can produce must be known and multiplied by the rate that they are produced. This is due to the fact that a gamma source does not produce a single energy level but instead there is a range of energies produced.
yi = The initial Yield from this source before any decay
Ei = the initial energy of this source before any decay
E = the energy of the photons
i = The value of i on its own refers to the fact that the calculation must use the initial values of μen/ρ.
r^2 = the distance away that the measurement is taken
please could someone check that this is correct. we were not given this formula or taught how to use it so I am struggeling.
If you weren't given that formula, where did you get it from? It's far easier to use the gamma constant for Cs-137, especially since they didn't give you the value for μen/ρ, which changes depending on photon energy. Your formula should read
X=5.263 x 10-6A∑(yiEien/ρ)i)/r2, where the summation is over all photon energies. However, when you use the gamma constant, this summation is already calculated for you.
We weren't given anything for this calculation, as a group we found an online calculator that said this was the formula for it. Although it'd be fantastic if there is a simpler way, I'm not sure how to do what you suggested either
There are numerous sources for the gamma constant (G) for Cs-137. The Rad Health Handbook lists the gamma constant as 3.3 R-cm2/hr-mCi, and the formula would be X = AG/r2, so all you need to do is perform some algebra and unit conversions to get the activity.
this is FAR easier, thank you
A = xr2 / G
so then i need to convert the units for G to bequerels? but what is R in the R-cm2/hr-mCi
does that mean its 3.3 x 1002 is equal to the value in milicuries?
1002 due to my calculation being at 1m
Yes, millicuries to Becquerels, and R (Roentgen) to mGy. 1 rad = 0.877 roentgen
Related to Rearrangement of a complex radiation formula
1. What is the purpose of rearranging a complex radiation formula?
Rearranging a complex radiation formula allows scientists to manipulate the equation in order to solve for a specific variable or to simplify the equation for easier analysis.
2. How do I know when to rearrange a complex radiation formula?
If you are trying to solve for a specific variable or simplify the equation for analysis, it may be necessary to rearrange the formula. Additionally, if the current form of the equation is difficult to work with, rearranging it may make it easier to use.
3. What are the steps for rearranging a complex radiation formula?
The first step is to identify the variable you want to solve for or simplify the equation for. Then, use algebraic principles such as multiplication, division, addition, and subtraction to isolate the variable on one side of the equation. Finally, double check your work and make sure the equation is in its simplest form.
4. Are there any specific rules or guidelines for rearranging a complex radiation formula?
There are no specific rules, but it is important to keep track of the operations being performed and to apply them correctly. It is also important to follow the order of operations (PEMDAS) when manipulating the equation.
5. Can rearranging a complex radiation formula change the meaning of the equation?
Rearranging a complex radiation formula should not change the overall meaning of the equation, as long as the operations are applied correctly. However, it may change the way the equation is written or presented.
  • General Math
