Rearranging equation for heat capacity
In summary, a student is trying to determine if a shiny gold rock is actually gold by measuring its heat capacity. The student finds that the specific heat capacity of the substance composing the rock is 0.128 J/g x Celsius. By using the equation q = m x Cs x temperature change, the student is able to determine the specific heat capacity of the rock, which leads to the conclusion that the rock is consistent with being pure gold. The student is also asked to solve symbolically for cs, which involves rearranging the equation so that cs is on the left side.
FLgirl
1. To determine whether a shiny gold rock is actually gold, a student decides to measure its heat capacity. She first weighs the rock and finds it has a mass of 4.7g. She then finds that upon absorbtion of 57.2 J of heat, the temperature of the rock rises from 25 degree Celsius to 57 degree Celsius. Find the specific heat capacity of the substance composing the rock and determine whether the value is consistent with the rock being pure gold.
2. q = m X Cs X temperature change
Cs of gold = 0.128 J/g x Celsius
3. 4.7g X 0.128 J/g x C X 32 C = 19.25
c = 9/temperature change = J/C = 57.2/32 C
4.7g X 32 C / 57.2 J
Actual solution: 57.2 J / 4.7g X 32 CSo my question is; why is 57.2 divided by the others, when if you had brought it over from the other side, wouldn't you divide it BY 57.2?
No idea what you are doing here.
[tex]q = mc_s\Delta T[/tex]
Solve for cs. Don't put numbers into the equation yet, just solve symbolically.
How do you do that... why are chemists so cryptic
Solve symbolically means rearrange so that cs will be on the left hand side of the equation and everything else will be on the right hand side.
There is nothing cryptic here, this is basic algebra that you should learn long ago. And if you have read forum rules you know we don't give final answers, we rather help you solve the problem guiding you in the right direction.
I would like to clarify that the equation for heat capacity is actually q = m x c x delta T, where q is the amount of heat absorbed, m is the mass of the substance, c is the specific heat capacity, and delta T is the change in temperature. Therefore, the rearranged equation should be c = q / (m x delta T).
To answer your question, in this specific scenario, we are trying to find the specific heat capacity of the substance composing the rock, which is represented by c. The value of 57.2 J is given as the amount of heat absorbed by the rock, and we divide it by the other values (mass and temperature change) to find the specific heat capacity. This is because we are trying to isolate the value of c in the equation.
I hope this helps clarify any confusion. It is important to always use the correct equation and rearrange it properly to get accurate results in scientific experiments.
Related to Rearranging equation for heat capacity
1. What is the formula for calculating heat capacity?
The formula for calculating heat capacity is C = Q / ΔT, where C is the heat capacity, Q is the amount of heat absorbed or released, and ΔT is the change in temperature.
2. How do I rearrange the heat capacity equation to solve for Q?
To solve for Q, the equation can be rearranged to Q = C x ΔT. This means that the amount of heat absorbed or released (Q) is equal to the heat capacity (C) multiplied by the change in temperature (ΔT).
3. Can the heat capacity equation be used for any substance?
Yes, the heat capacity equation can be used for any substance. However, the value of the heat capacity may vary depending on the substance, as different materials have different abilities to absorb and retain heat.
4. How is heat capacity related to specific heat capacity?
Heat capacity (C) is the amount of heat required to raise the temperature of a substance by a certain amount, whereas specific heat capacity (c) is the amount of heat required to raise the temperature of 1 gram of a substance by a certain amount. The relationship between the two is C = m x c, where m is the mass of the substance.
5. Can the heat capacity equation be used in real-life situations?
Yes, the heat capacity equation can be applied to real-life situations, such as in engineering and thermodynamics. It is commonly used to calculate the amount of energy needed to heat or cool a substance, and plays a crucial role in understanding and designing systems that involve heat transfer.
  • Thermodynamics
