Rearranging equations of accelerated motion
In summary: So (1/2) * 0.333 * t^2, represents the distance travelled by Go Cart B during the same time that Go Cart A takes to travel 1000 m.If you can't re-arrange the formula with all the terms in it, substitute the known values then just solve the problem with only 1 pro-numeral [a] and a whole lot of digits.Once the numbers are substituted, this becomes a Junior High school equation to solve.So (1/2) * 0.333 * t^2, represents the distance travelled by Go Cart B during the same time that Go Cart A takes to travel 1000 m.In summary, the first question involves finding the acceleration of
jjesiee
theres two questions actually.
1) a boat increases its speed from 5.0 m/s to 7.5 m/s over a distance of 50.0m. what it the boat's acceleration?
2) within 4.0s of liftoff, a spacecraft that is uniformly accelerating straight upward from rest reaches an altitude of 4.50 x 10^2 m [up]
a) what is the spacecraft 's acceleration
b)at what velocity is the spacecraft traveling when it reaches this altitude?
for 1) i just need to rearrange vf^2 = vi^2 +2aΔd to find acceleration
for 2a) the same thing but with the equation, Δd=viΔt + 1/2aΔt^2
ive tried rearranging the equation but i get stuck and i don't know what to do next. please help
You want to use algebra to isolate the variable a, that is, to get it all alone on one side of the equation. Since it is an equation you can perform the same operation to both sides of the equal sign to change its form but not its meaning. For example, if you were trying to isolate z in [itex] x = p + dz [/itex] you would start by subtracting p from both sides. This leaves you with [itex] x - p = dz [/itex]. Now to isolate z we can divide both sides by d to get [itex] \frac{x - p}{d} = z [/itex]. Can you apply a similar process to [itex] v^2 = v_0^2 + 2 a \Delta x [/itex] to isolate a?
Im not really good at this but i tried:
vf^2 = vi^2 + 2a Δd
vf^2/2a = vi^2 + Δd
am i doing this right? I just want to know how to get rid of vf^2/2a so i can isolate 2a.
vf^2 = vi^2 + 2a Δd
vf^2/2a = vi^2 + Δd
That's not quite right. Remember that if you want to divide through by "a" you need to do it to every term. What if you started by subtracting vi^2 from each side of the equation and then diveded through by 2Δd? Dividing by "a" first is not that helpful.
I'll show you the first step,
[tex] vf^2 = vi^2 + 2a Δd [/tex]
subtract [itex] vi^2 [/itex] from both sides
[tex] vf^2 - vi^2 = vi^2 - vi^2 + 2a \Delta d [/tex]
[tex] vf^2 - vi^2 = 0+ 2a \Delta d [/tex]
[tex] vf^2 - vi^2 = 2a \Delta d [/tex]
Now to get a all by itself we need to divide both sides by 2Δd. Can you try this and repost if you are still not sure?
no i got it :D thanks a lot . I was probably just thinking too much but now i have another problem. If you don't mind can you help me with that question?
Two go carts A and B race each other around a 1.0 km track. Go-cart A travels at a constant speed of 20.0 m/s. Go cart B accelerates uniformly from rest at a rate of 0.333 m/s^2. Which go-cart wins the race and by how much time?
The answer at the back says A wins by 27 s.
For this question, I know that Δd = 1000 m
a= 0.333 m/s^2
and that were looking for Δt.
I just don't know how to go about. I was thinking that I have to use two separate equations.
You're right in that a good approach is to find the time it takes each car to travel the track and compare them (Δt for each). You can use this equation
[tex]
x = x_0 + v_0 t + (1/2) a t^2
[/tex]
In the case of no acceleration "a" would just be zero.
[tex]
[/tex]
give me another hint? i don't get it :s
FAQ: Rearranging equations of accelerated motion
1. What is the equation for finding final velocity in terms of initial velocity, acceleration, and time?
The equation for finding final velocity is v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time.
2. How do you rearrange the equation for finding displacement in terms of initial and final velocity, acceleration, and time?
To rearrange the equation for finding displacement, start with s = ut + 1/2at^2 and substitute in the equation v = u + at. This will give you the rearranged equation: s = (v+u)/2 * t.
3. Can you rearrange the equation for finding time in terms of displacement, initial and final velocity, and acceleration?
Yes, to rearrange the equation for finding time, start with s = ut + 1/2at^2 and substitute in the equation v = u + at. This will give you the rearranged equation: t = (v-u)/a.
4. How do you solve for acceleration when given initial and final velocity, displacement, and time?
To solve for acceleration, use the equation v^2 = u^2 + 2as. Substitute in the given values for v, u, and s, and then solve for a.
5. Is there a shortcut for rearranging equations of accelerated motion?
Yes, the "SUVAT" equations are a set of four equations that can be used to solve for different variables in accelerated motion problems. They are: v = u + at, s = ut + 1/2at^2, v^2 = u^2 + 2as, and s = (v+u)/2 * t.
