Reason for the irrationality of (most) square roots?
In summary: If there were a "deeper mathematical reason" for the irrationality of square roots, it would probably have something to do with the fundamental theorem of arithmetic and the distribution of prime numbers.In summary, the conversation discusses the fact that the square root of any integer that is not a perfect square is always an irrational number. The participants question the reason for this and discuss various proofs and mathematical concepts, such as factorization into primes and the fundamental theorem of arithmetic. They also mention the surprising occurrence of irrational numbers in various calculations and the potential for a deeper mathematical reason behind the irrationality of square roots.
thebosonbreaker
32
The square root of any integer that is not a square number is always an irrational number.
I find this fact rather spectacular, but my question is why is this true? I have seen the formal proof for the irrationality of root 2 so I could vaguely see how one could prove that all (apart from sq numbers) integer square roots are irrational, but the real question I'm asking here is WHY is it true - is there a deeper mathematical reason? Or is it simply down to a coincidence?
Thank you for your help in advance.
Mathematics news on Phys.org
What do you mean by "deeper mathematical reason"? It is possible to show this in general by using factorisation into primes. Meaning in mathematics never goes further than "follows from the axioms".
Likes thebosonbreaker
The rational numbers are those numbers, which extend the mulitiplicative halfgroup of the integers, that is ##\{\ldots ,-2,-1,1,2,\ldots\}## to a group, that is a set that allows inverses. In other words, we add all solutions of the equation ##a\cdot x \stackrel{(1)}{=} 1##.
To get square roots, we would need to solve ##x^2\stackrel{(2)}{=}a## which is a different equation, which already says, that it's only solvable for squares. That a solution to (1) cannot lead to a solution of (2) except for squares is then the proof you know.
Most real numbers are irrational. As soon as you do something that is not guaranteed to give a rational number (like adding two rational numbers), you typically get irrational numbers.
Likes WWGD, thebosonbreaker and FactChecker
There are some funny "rules" about what kind of irrational numbers are obtained by certain calculations, for example taking the sine or cosine of rational multiples of ##\pi## will give square roots of rational numbers as a result, while taking the gamma function of half-integers ##\frac{2n+1}{2}## will give multiples of ##\sqrt{\pi}##...
Wait... you mean this continued fraction terminates somewhere, after hundreds of terms that are not zero? Or do you mean just a few specific rational multiples?
Edit: Found a clear counterexample. The square is an algebraic number, but not a rational number.
Likes hilbert2
Oh, then I remembered it wrong. I just had an image of some tables of trigonometric functions in mind and didn't think more about it.
I meant that whilst it is possible to show the irrationality (there are a lot of different ways - factorisation into primes as you mention being one of them).. is there more of a "reason" for it? It just seemed to me like a heavy coincidence that these non-perfect square roots generate an infinite number of irrational numbers and all seem to follow this rule of irrationality.
Thank you for your insight, but what exactly do you mean when you say that "mathematics never goes further than follows from the axioms" in this context?
Yes thanks for your help, it seems easily proven but at the same time a large coincidence that these non-perfect square roots follow a certain rule of irrationality, so to speak. I was wondering if there was more of a logical / deeper reasoning behind it.
Hi, thanks for your help. Yes... irrational numbers continue to astonish me! It's incredible in many of the areas of Maths in which they appear. Usually irrational numbers aren't easy to find by calculation (yes ok - there are of course infinitely many of them, but...) it seems strange to me that using these square roots is such a seamless way of finding them. It's one thing to prove that they do this, but surely this property must have some sort of deeper reasoning.
Once again thanks for your insight into this.
Yes. ##\mathbb{Q}= \operatorname{span}_\mathbb{Z} \left( \mathbb{Z} \cup \{x \,\vert \, \exists \, a \in \mathbb{Z}\, : \,x\cdot a = 1\} \right) ## and this set doesn't contain all solutions to ##x^2\cdot a =1\,##. Or short: We made ##\mathbb{Q}## in order to divide, but division isn't enough to take all square roots. It simply isn't strong enough.
Likes QuantumQuest
Any number whose factorization has a prime to an odd power will have an irrational square root. As numbers get larger and have a greater number of distinct prime factors, the odds that one will be to an odd power increases. That would imply many more irrational square roots than rational.
Likes Janosh89
It can be proved that if ##r## is a rational zero of a polynomial ##\sum_{k=0}^n a_kx^k## with integer coefficients, then ##a_nr## is an integer. In particular, if this polynomial is monic, that is, if ##a_n=1##, then ##r## is an integer.
A consequence of this is that if the ##n##-th root of an integer is rational, it is an integer.
Likes Greg Bernhardt and mfb
FAQ: Reason for the irrationality of (most) square roots?
1. What is the reason for the irrationality of most square roots?
The reason for the irrationality of most square roots is that they cannot be expressed as a ratio of two integers. In other words, the decimal representation of these square roots never terminates or repeats, making them irrational numbers.
2. Are there any exceptions to the irrationality of square roots?
Yes, there are a few exceptions to the rule that most square roots are irrational. Some perfect squares, such as 4 or 9, have rational square roots that can be expressed as whole numbers. Additionally, some square roots can be simplified to rational numbers, such as the square root of 8, which can be simplified to 2√2.
3. How can you prove that a square root is irrational?
There are a few different methods for proving that a square root is irrational. One common method is by contradiction, where you assume that the square root is rational and then show that this leads to a contradiction. Another method is by using the rational root theorem, which states that if a polynomial with integer coefficients has a rational root, it must be a divisor of the constant term.
4. What makes irrational numbers different from rational numbers?
Irrational numbers are different from rational numbers because they cannot be expressed as a ratio of two integers. Rational numbers, on the other hand, can be expressed as fractions, decimals, or whole numbers. Irrational numbers also have decimal representations that never repeat or terminate, while rational numbers have finite or repeating decimal representations.
5. How are irrational numbers used in real life?
Irrational numbers have many real-life applications, particularly in math, science, and engineering. They are used in calculations for measurements, such as finding the area and circumference of a circle. Irrational numbers are also used in the fields of physics, statistics, and finance to model and analyze complex systems and phenomena. In technology, irrational numbers are used in computer algorithms and coding, and in art and music, they can be used to create patterns and harmonies.
11K
