Reccurent vs. Transient in Stochastic proccess.
In summary, the conversation discusses the possibility of a Markov Chain with infinite recurrent and transient states and the application of the strong law of large numbers in determining the recurrence or transience of states in a given Markov Chain. The speaker provides hints and guidance for finding the answers to these questions, emphasizing the importance of understanding the definitions and properties of Markov Chains.
MathematicalPhysicist
373
I have a few quetions which I'm trying to answer, hope someone can hint me to the right answer.
1.Prove/disprove that there doesn't exist a Markov Chain with transition matrix which all of its entries are positive and which it has infinite transient states and infinite reccurent states.
2. There's given a Markov chain which its states are the integers, and for each i, the transition probabilities are given by:
[tex]P_{i,i-1}=P_{i,i}=P_{i,i+1}=1/3[/tex]
Can we sort out the states of the chain (as reccurent or transient) with the help of the strong rule of the large numbers?
For 1, I think that such a matrix obviously should be infinite, the problem is that I think that in this case each states would be reccurent and not transient so the statement is valid.
Not sure how to rigourosly write it though.
For 2, I've computed the expectation value and it's value is 0, Now if we were to use the strong rule, then it means that the culminated averages of the displacement approches zero, which means that: [tex]\frac{\sum_{i=0}^{n}X_i}{n}\rightarrow 0 [/tex] as [tex]n\rightarrow \infty[/tex], which means that: [tex]\sum_{i=0}^{\infty} X_i< \infty[/tex] but not necessarily zero, so we can't know for sure if 0 is transient or reccurent, if this sum was zero, then it would be reccurent from the strong law because we visit zero infinite times, and if it were other value then it would be transient.
Am I way off here, or on the right track?
Thanks in advance.
Hello,
Thank you for your questions. I will try to provide some guidance and hints to help you find the answers to your questions.
1. To prove or disprove the existence of a Markov Chain with the given conditions, you can start by considering the definition of recurrent and transient states. A state is recurrent if it is possible to return to that state infinitely many times, and it is transient if there is a non-zero probability of never returning to that state. With this in mind, think about the implications of having an infinite number of recurrent and transient states in a Markov Chain. Can you come up with an argument for why this may not be possible?
2. For the second question, you are on the right track. The strong law of large numbers states that the average of a sequence of random variables will converge to the expected value as the number of terms in the sequence increases. In this case, the expected value is 0, but as you mentioned, this does not necessarily mean that the sum of the sequence will be 0. However, keep in mind that the strong law of large numbers only applies to independent and identically distributed random variables. Can you determine if the sequence of displacements in this Markov Chain satisfies these conditions?
I hope this helps you in finding the answers to your questions. Remember to always think critically and carefully consider the definitions and properties of Markov Chains when approaching these types of problems. Good luck!
FAQ: Reccurent vs. Transient in Stochastic proccess.
What is the difference between recurrent and transient in stochastic processes?
Recurrence and transience are two properties of a stochastic process that describe the behavior of the process over time. Recurrence means that the process will eventually return to a given state with probability 1, while transience means that the process will eventually leave a given state with probability 1. In other words, a recurrent process will keep revisiting a state, while a transient process will eventually move on to other states.
How can we determine if a stochastic process is recurrent or transient?
The recurrence or transience of a stochastic process can be determined by analyzing the long-term behavior of the process. If the probability of returning to a given state infinitely often is 1, then the process is recurrent. If the probability of never returning to a given state is 1, then the process is transient.
Can a stochastic process be both recurrent and transient?
No, a stochastic process can only have one of these two properties. If a process is recurrent, it cannot be transient, and vice versa.
What types of stochastic processes are typically recurrent?
Markov chains, which are stochastic processes that satisfy the Markov property, are typically recurrent. This means that the future behavior of the process only depends on the current state, and not on the past states. However, not all Markov chains are recurrent, as this also depends on the specific transition probabilities of the process.
How do recurrent and transient properties affect the long-term behavior of a stochastic process?
The recurrence or transience of a stochastic process has a significant impact on its long-term behavior. For recurrent processes, the behavior will eventually settle into a steady state, while for transient processes, the behavior will continue to change over time. This can have implications for the predictability and stability of the process.
