Recoil of wedge when block slides down
  • Thread starter dorian_stokes
  • Tags
    Block Wedge
In summary: Hence equation (1) becomes:y = X*sinθ.Thus, the block slides down the wedge with an acceleration of x=mg*cosθ - N. The block travels a distance of y=X*sinθ from the top of the incline to the bottom.
dorian_stokes
25
A block of mass 3.1 kg is initially at rest on a wedge of mass 19 kg, height 0.20 m, and an incline angle of 30° as shown in the figure below. There is no friction between the wedge and the floor. Starting at the top of the incline, the block is released and slides toward the bottom of the wedge. At the same time, the wedge "recoils" and slides some distance L to the right. Find L when the block has reached the bottom of the wedge.
In the problem it is stated that there is no friction between the wedge and the floor. I presume that there is no friction between wedge and block.
The block fall freely vertically through a distance Y. As a recoil the wedge moves through X horizontally. Resolve Y into two components: y, perpendicular to inclined plane and x, parallel to the inclined plane. If you draw the free body diagram, you can see that y = X*sinθ. Hence acceleration ay = aX*sinθ,...(1) where aX is the acceleration of wedge.
For the block, mg*cosθ - Ν = m*ay...(2) and mg*sinθ = m*ax...(3)
For wedge N*sinθ = M*aX...(4)
From equation (1), (2) and (4) solve for aX.
From equation(3), find the time t taken by the block to slide down the inclined plane.
Using the kinematic equation find the distance L traveled by the wedge in time t.
I'm totally confused. Can you make the variables for acceleration a little clearer. And wouldn't the normal be applied to the y and not the x components when finding the sum of forces?
Consider the block and wedge separately.
Forces acting on wedge:
Weight of the wedge Mg towards the base.
Normal reaction N1 on the base in the upward direction.
These two forces won't contribute to the motion of the wedge.
Normal reaction N due to the block on the wedge acts normal to the inclined plane.
Its component parallel to the base, ( N*sinθ ), pushes the wedge towards right with acceleration aX. So ( N*sinθ ) = M*aX...(4)
Forces acting on the block:
Froce mg acting vertically downwards.
Normal reaction N due to wedge, normally away from the inclined plane.
mg*sinθ accelerates the block along the inclined plane ( along x direction). So mg*sinθ = ax.
The net force (mg*cosθ - N) pushes the block towards the inclined plane ( along y direction). So (mg*cosθ - N) = m*ay ...(2)
If aX is the acceleration of the wedge in the horizontal direction, then ay = aX*sinθ
FAQ: Recoil of wedge when block slides down
1. What is the recoil of a wedge when a block slides down?
The recoil of a wedge when a block slides down refers to the backward force or motion that is generated in the wedge due to the block's downward movement.
2. How does the angle of the wedge affect the recoil when a block slides down?
The angle of the wedge plays a crucial role in determining the magnitude of the recoil. A steeper angle will result in a greater recoil force, while a shallower angle will result in a smaller recoil force.
3. What factors influence the recoil of a wedge when a block slides down?
Apart from the angle of the wedge, the mass of the block, the coefficient of friction between the block and the wedge, and the velocity of the block also influence the recoil force.
4. Can the recoil of a wedge be eliminated?
No, the recoil of a wedge cannot be completely eliminated as it is a natural consequence of the block sliding down the wedge. However, it can be minimized by adjusting the angle of the wedge or reducing the mass or velocity of the block.
5. What is the practical application of studying the recoil of a wedge when a block slides down?
The study of the recoil of a wedge when a block slides down has practical applications in various fields, such as engineering and mechanics. It helps in understanding the forces involved in objects sliding on inclined planes and can be used to design more efficient and stable structures.
