Recording gravity waves over the noise floor
In summary, gravity waves are ripples in space-time caused by the acceleration of massive objects and are recorded using interferometers. The noise floor in gravity wave detection refers to the level of background noise that interferes with detection, making it important to record gravity waves above this level. To reduce noise, scientists use techniques such as shielding, canceling noise signals, and analyzing data from multiple detectors.
musichascolors
I'm curious as to how the gravity waves were recorded given how small the amplitude of the wave was/is. Was it not below the thermal noise floor? Were noise removal techniques used, etc?
Also, what kind of sampling rate/bit depth was used?
Thanks
You probably mean gravitational waves. Gravity waves are water waves, for example.
As you can see in the publications, the noise was smaller than the observed signal, and a lot of effort was put into noise reduction.
All the other details are in the publications as well.
Related to Recording gravity waves over the noise floor
What are gravity waves?
Gravity waves are ripples in the fabric of space-time caused by the acceleration of massive objects, such as colliding black holes or supernova explosions.
How are gravity waves recorded?
Gravity waves are recorded using highly sensitive instruments called interferometers, which use laser beams to measure tiny distortions in space-time caused by passing gravity waves.
What is the noise floor in gravity wave detection?
The noise floor in gravity wave detection refers to the level of background noise that interferes with the detection of gravity waves. This noise can come from a variety of sources, such as seismic activity, atmospheric disturbances, and technical limitations of the instruments.
Why is recording gravity waves over the noise floor important?
Recording gravity waves over the noise floor is important because it allows scientists to accurately measure and study the properties of these waves. It also helps to distinguish between real gravity wave signals and false signals caused by noise.
What are some techniques used to reduce noise in gravity wave detection?
Scientists use various techniques to reduce noise in gravity wave detection, such as shielding the instruments from external disturbances, actively canceling out noise signals, and analyzing data from multiple detectors to filter out noise.
