Rectangle incribed in an ellipse
In summary, when trying to solve for y as a function of x in an equation of an ellipse, you can use the equation x2/4+ y2/9= 1, and either use the "Lagrange multiplier method" or differentiate.
brizer
Problem: What is the area of the largest rectangle that can be inscribed in the ellipse 9x2+4y2=36
Relevant Equations:
equation of an ellipse: (x - h)2/a2 + (y - k)2/b2 = 1
I only got as far as
x2/4 + y2/9 = 1
(x - 0)2/22 + (y - 0)2/32 = 1
I have no idea where to go from here
I think you can assume that the rectangle has sides parallel to the x and y axes. Okay, if one vertex of the rectangle is at (x,y), the other four vertices are at (x, -y), (-x, y), and (-x,-y). The lengths of the two sides are 2x and 2y and the area is xy.
Knowing that x2/4+ y2/9= 1, you could solve for y as a function of x, write A= xy as a function of x only and differentiate.
Or, if you know the method, it would be simpler to use the "Lagrange multiplier method" to directly minimize xy with the condition x2/4+ y2/9= 1.
The problem with not showing any work is that we don't know what methods you are familiar with.
Sorry, it's been two years since geometry so I was glad I could even remember the formula for an ellipse. My work was pretty much an ellipse with a triangle in it and my book is no help since my math teacher made up this summer homework on a whim. At any rate, I'm not familiar with the Lagrange multiplier method, so I wrote A=xy as a function of x and differentiated.
(x2/4) + (y2/9) = 1
(x/2) +(y/9) = 1
3x + 2y = 6
2y = 6-3x
A=(2x)(6-3x)
A=(12x-6x2)
A'=12-12x
So, from here do I just plug in variable a for x and solve? That would give me a negative area. Basically, I get that the points where the rectangle and ellipse touch are parallel, but I don't understand how you find them.
Why is the area xy? Shouldn't it be A = 2x(2y) instead?
brizer said:
(x2/4) + (y2/9) = 1
(x/2) +(y/9) = 1
3x + 2y = 6
2y = 6-3x
How does this follow from the previous step?
Yes, you are right. Sorry about that.
FAQ: Rectangle incribed in an ellipse
What is a rectangle inscribed in an ellipse?
A rectangle inscribed in an ellipse is a rectangle whose four corners touch the edge of an ellipse at four different points. This means that the rectangle's sides are tangent to the ellipse.
What are the properties of a rectangle inscribed in an ellipse?
A rectangle inscribed in an ellipse has several interesting properties. Its diagonals are equal in length and bisect each other, forming four right angles at the point of intersection. Additionally, the rectangle's sides are parallel to the major and minor axes of the ellipse.
How is the area of a rectangle inscribed in an ellipse related to the area of the ellipse?
The area of a rectangle inscribed in an ellipse is always equal to half the area of the ellipse. This means that the rectangle's area is always less than the area of the ellipse, with the difference becoming smaller as the rectangle approaches being a square.
Can a rectangle inscribed in an ellipse have any dimensions?
Yes, a rectangle inscribed in an ellipse can have any dimensions as long as it meets the criteria of being tangent to the ellipse at four points. This means that the rectangle's sides can be any length, as long as they are equal and parallel to the major and minor axes of the ellipse.
How can a rectangle inscribed in an ellipse be useful in real life applications?
Rectangles inscribed in ellipses can be found in various real life applications, such as architecture, engineering, and art. They can be used in the design of buildings, bridges, and sculptures to create visually appealing and structurally sound structures. In mathematics, the concept of a rectangle inscribed in an ellipse is important in understanding the properties of conic sections and their applications.
