Rectangular Waveguide centered at the origin
In summary, for a rectangular waveguide centered at x=a/2, y=b/2, the solution for TE mode is H = Ho Cos(m*pi*x/a) * Cos(n*pi*y/b) (n,m = 0,1,2,...). If centered at the origin, the solutions are H = Ho Cos(m*pi*x/2a) * Cos(n*pi*y/2b) (n,m odd) and H = Ho Sin(m*pi*x/2a) * Sin(n*pi*y/2b) (n,m even). The corresponding values for n=1 and m=1 give the same mode as the one centered at (a/2,b/2), but with a half-wavelength shift
phys_student1
106
Hello,
If a rectangular waveguide (or square well, etc) is centered at x=a/2, y=b/2, solution (e.g. for TE mode) is:
So for TEn=0,m=1, H = Ho Cos(pi*x/a).
If it is centered at the origin, you get even and odd solutions:
Now, what is the corresponding values for n,m that give the same mode?
For the mode centered at the origin, you can use n=1 and m=1. This gives you the same mode as the one centered at (a/2,b/2). The difference is that the waveform is shifted by half-wavelength. Hope this helps.Regards,Your Name
Related to Rectangular Waveguide centered at the origin
1. What is a rectangular waveguide centered at the origin?
A rectangular waveguide centered at the origin is a type of electromagnetic waveguide that has a rectangular cross-section and is centered at the origin of a coordinate system. It is used for guiding and transmitting electromagnetic waves, typically in the microwave frequency range.
2. How does a rectangular waveguide centered at the origin work?
A rectangular waveguide centered at the origin works by confining and guiding electromagnetic waves within its walls. The walls act as mirrors, reflecting the waves along the length of the waveguide and keeping them from escaping. The dimensions of the waveguide determine the frequencies of waves that can be transmitted through it.
3. What are the advantages of using a rectangular waveguide centered at the origin?
One advantage of using a rectangular waveguide centered at the origin is its ability to transmit high-power electromagnetic waves without significant loss. It also has a wide bandwidth and can be used for both single and multiple frequency transmission. Additionally, it is a relatively simple and cost-effective design.
4. What are the limitations of a rectangular waveguide centered at the origin?
One limitation of a rectangular waveguide centered at the origin is its size and weight, which can be a disadvantage in certain applications. It also has a limited range of usable frequencies, as the dimensions of the waveguide must be carefully chosen to match the desired frequency range. Additionally, it is not suitable for transmitting signals over long distances.
5. How is a rectangular waveguide centered at the origin different from other types of waveguides?
A rectangular waveguide centered at the origin is different from other types of waveguides, such as circular or elliptical waveguides, in terms of its shape and mode of operation. It is also different from coaxial cables, which have a cylindrical shape and use a different mode of transmission. Additionally, the dimensions and frequency range of a rectangular waveguide centered at the origin can vary depending on its specific design and application.
  • Classical Physics
  • Classical Physics
  • Topology and Analysis
