MHB Recurrence relation - initial condition
The discussion focuses on solving the recurrence relation T(n) = 2T(√n) + 1, leading to the transformation S(m) = 2S(m/2) + 1. It establishes the need for an initial condition, suggesting T(2) = S(1) = c, with derived values T(0) = -1 and T(1) = -1. The solution ultimately indicates that T(n) equals -1 for all n, which is confirmed through iterative calculations and limits. The conclusion raises questions about the validity of this result, highlighting its unusual nature.
evinda
MHB
Hello! (Smile)
I want to find the exact solution of the recurrence relation: $T(n)=2T(\sqrt{n})+1$.$$m=\lg n \Rightarrow 2^m=n \\ \ \ \ \ \ \ \ \ 2^{\frac{m}{2}}=\sqrt{n}$$
So we have: $T(2^m)=2T(2^{\frac{m}{2}})+1$
We set $T(2^m)=S(m)$, so we get: $S(m)=2S \left( \frac{m}{2}\right)+1$
$$S(m)=2S \left( \frac{m}{2}\right)+1=2^2S\left( \frac{m}{2^2} \right)+2+1= \dots= 2^i S \left( \frac{m}{2^i}\right)+ \sum_{j=0}^{i-1} 2^j$$If we would have an initial condition, let $S(1)=c$ then we would say that the recursion ends when $\frac{m}{2^i}=1$.
So that the recurrence relation is well-defined, it has to hold the following:
$$ n>\sqrt{n} \Rightarrow n^2>n \Rightarrow n^2-n>0 \Rightarrow n(n-1)>0 \Rightarrow n>1 \wedge n>0 \Rightarrow n \geq 2 \Rightarrow 2^m \geq 2 \Rightarrow m \geq 1$$So does this mean that we have to set $T(2)=S(1)=c$ ? (Thinking)
Your initial condition would probably have to be in terms of T(n), not S(n). You can find T(0)= -1 and T(1) = -1 from the equation, though.
If you use the method from my post in http://mathhelpboards.com/discrete-mathematics-set-theory-logic-15/solve-f-n-2f-sqrt-n-n-14405.html, you can find the solution of your recurrence to be
$$ T(n) = \left ( T(2) +1 \right ) \log_{2} n - 1, n = 2^{2^k}.$$
I'm not sure exactly how to solve this for T(2), though. If you take $ T(2) = 2 T( \sqrt 2 ) +1 $ and iterate, you have
$$ T(2) = 2^c T( \sqrt[c] 2 ) +2^{c} - 1 $$ for all $ c \geq 1 $.
Taking the limit, you get
$$ T(2) = \lim_{c \to \infty} \left ( 2^c - 2^c -1 \right ) = -1, $$
which implies that
$$ T(n) = ( -1 +1 ) \log_2 n -1 = -1 $$ for all n.
:confused: This seems to be really weird, until you take the limit as $ i \to \infty $ of the final recurrence relation in your post, which gives us the same answer.
Either I am horribly wrong, or this is the correct solution.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
