Recursive sequence calculators
luckis11
required for solving differential equations by elementary calculus
all differential equations
I know the http://www.calcul.com/ but it is offline some days. Do you know any other online free ones? I.e. that calculates the far values of a recursive sequence.
I need the values in order to test if the fit with my solution. And when the solution of the differential equation is unknown or weird, the only solution is the values of the recursive sequence! Usually I do not know what the differential equation is before I make up what the recursive sequence is. Every physicist and mathematician should know this, but I bet there are very few who can solve the differential equation through the relevant recursive sequence, like I do, which is what they did in the 1700's I guess.
Actually I find it strange that some differential equations cannot be solved through the relevant recursive sequence and they are solved otherwise, e.g. x"(t)=-kx'(t)^2, x(0)=0, x'(0)=U. Its recursive sequence is
u(n)=u(n-1)-ku(n-1)^2dt or u(n)=u(n-1)-ku(n)^2dt
where each next u(n) corresponds to a next dt. But this sequence cannot be solved. In other cases it can, e.g. at Stokes drag x''(t)=-kx'(t), x'(0)=U, x(0)=0, its recursive sequence is
u(n)=u(n-1)-ku(n-1)dt, u(0)=U=>u(n)=U(1 - dt k)^n
and you place n=t/dt (because 1 sec has 1/dt number of changes, therefore t secs have t*1/dt=n number of changes) and
lim dt->0 U(1 - dt k)^(t/dt)=Ue^(-k t)=u(t)=x'(t).
which is the solution of the differential equation. Partly, since this is only the x'(t), I haven't tried to solve for x(t).
Note that wolframalfa in some cases it gives semi-wrong and in some cases no answer for x"(t)=-kx'(t)^2, x(0)=0, x'(0)=U. If you plug it in like I wrote it, it gives an answer with i. What am I supposed to do with i?
This is all very difficult to read, you should learn to post in ## \LaTeX ## math (I see you have been told this before).
This is a very strange thing to say. What makes you think that you know something very few other people know? How did you come by this knowledge?
This is not how you solve differential equations with recurrence relations, you do it by comparing coefficients.
Well if you have ## x'(t) = U e^{-kt} ## then it should be easy for you to find ## x(t) ##.
Why do you think that Wolfram Alpha calculates this incorrectly? Have you checked it by differentiating? Note that it is easy to link to a solution on Wolfram Alpha by copying the contents of the address bar like this:
https://www.wolframalpha.com/input/?i=x''(t)=-kx'(t)^2,+x(0)=0,+x'(0)=U
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
