Red light to green light homework
In summary, to calculate the speed of a vehicle needed to turn a red traffic light into a green traffic light, you can use the Doppler shift formula. This equation takes into account the frequency and wavelength of both the red and green lights, as well as the speed of light. By solving for v, you can determine the necessary velocity of the vehicle.
espania
What speed would a vehical have to travel in order to red traffic light into a green traffic light?
i know that green light has wavelength of 5.40x10^-7 m
frequency of 5.56x10^14 hz
red light has wavelength of 6.60x10^-7 m
frequency of 4.54x10^14 hz
so do i use velocity = wavelenght x freq
for the 2 and then subtract the small from the large?
No, the speed of light is always c, it doesn't depend on the frequency.
The only way to 'change' the frequency/wavelength is to approach or move away from the source.
Use the doppler shift formula and plug in the numbers. Take good note of what the numbers in the formula mean, so you won't confuse signs.
ok this is what i did.,
5.56 x 10^14 = (3x10^8 / 3x10^8 x v) 4.54 x 10^14
5.56 x 10^14 = (v) 4.54 x 10^14
so v = 1.2ms?
Nope.U need to open the book first and read the correct version of Doppler-Fizeau formulas...I think they mean the longitudinal effect...
Daniel.
is there one of you guys have grifftihs electrodynamics solution?:)please snd to my email
You can search the net for solutions,but i would't trust them,if i were you...
Daniel.
Ok where could I find or could anybody give me the formula for the doppler shift when traveling at speeds close to the speed of light.
So I need to take relativity into account.
I needs this as soon as possible, thanks.
The formula you should use is not in your book?
[tex]\frac{\lambda '}{\lambda}=\sqrt{\frac{c-v}{c+v}}[/tex]
where [itex]\lambda '[/itex] is the Doppler-shifted wavelength and [itex]v[/itex] is the relative velocity between source and observer (positive when approaching).
For v<<c, the approximation
[tex]\frac{\lambda'}{\lambda}=1-\frac{v}{c}[/tex]
will do.
I haven't a clue how to use this formula Galileo, because I am looking for v, and there are 2 v's in the equation.
Would you be able to explain how I do it, or do an eg. using different values.
I would really appreciate it. Thanks.
You'd have to solve the equation for v.
Show us how far you got. Obviously, you first have to square both sides of the equation to get rid of the square root. Then bring the numerator to the other side, and collect terms with v in it.
I just don't know where to start. I ve never seen this formula before.
How do I calculate v [the velocity of the car needed to turn red light to green light] from this equation ?? Please can somebody show me how?
Elementary algebra:
[tex]\frac{\lambda '}{\lambda}=\sqrt{\frac{c-v}{c+v}} \Rightarrow
\frac{\lambda'^2}{\lambda^2}(c+v)=(c-v)
\Rightarrow \frac{\lambda'^2}{\lambda^2}c+\frac{\lambda'^2}{\lambda^2}v+v=c[/tex]
[tex]\Rightarrow (1+\frac{\lambda'^2}{\lambda^2})v=c(1-\frac{\lambda'^2}{\lambda^2}) \Rightarrow v=\frac{c(1-\frac{\lambda'^2}{\lambda^2})}{(1+\frac{\lambda'^2}{\lambda^2})}=\frac{c(\lambda^2-\lambda'^2)}{(\lambda^2+\lambda'^2)}[/tex]
FAQ: Red light to green light homework
What is "Red light to green light homework"?
"Red light to green light homework" is a teaching strategy used in the classroom to help students monitor their own understanding of a topic. It involves placing a red light next to a question or concept that students do not fully understand and a green light next to a question or concept that they feel confident about.
How does "Red light to green light homework" help students?
This strategy helps students become more aware of their own learning by encouraging them to reflect on their understanding of a topic. It also allows teachers to quickly assess which concepts students may need more support with.
When should "Red light to green light homework" be used?
This strategy can be used for any subject or topic, but it is particularly useful for complex or challenging material. It can be used as part of regular homework assignments or as a formative assessment tool during class time.
Can "Red light to green light homework" be used for all ages and grade levels?
Yes, this strategy can be adapted for students of all ages and grade levels. Younger students may benefit from using pictures or symbols instead of lights, while older students may prefer to simply write "red" or "green" next to each question or concept.
What are the benefits of using "Red light to green light homework"?
Aside from helping students become more reflective and self-aware learners, this strategy also promotes a growth mindset by encouraging students to see mistakes or areas of confusion as opportunities for learning and improvement.
