Red shift and narrowband filters
In summary, a narrowband filter can be used to block out light pollution, but it depends on the filter and how narrow the band is. It is important to know the bandwidth of the filter. It is also important to know how much starlight the filter will block. Finally, it is important to know how much the filter will cost.
Kawakaze
144
Im planning on trying out some narrowband filters to hopefully dodge the light pollution here and get some nice photos, I was just wondering if red shift ever comes into play, could a distant object be shifted enough to be actually blocked by the filter? I know it depends on the filter and so on, I was hoping for a general idea before I break out the textbooks and calculator! :)
Astronomy news on Phys.org
You mean cosmological redshift due to the expansion of the universe? It doesn't exist on at the level of our local group of galaxies and you won't be imaging much beyond that.
I thought as much, better to confirm it before spending hundreds of euros on filters. I guess it goes on how narrow, is a narrowband filter? :)
Thanks Russ!
Like Russ said.
But let me elaborate a little.
The short answer is that things that might have a significant Doppler shift, such as galaxies, have a spectrum more-or-less like our sun, which is all over the spectrum. (no pun intended). So you don't have to worry about any light from galaxies being shifted out of the passband, because there would be just as much light shifted into it. Now a little more elaboration.
Narrowband filters are most profound on emission nebula. They not only block out nearly all the light pollution, but also a large portion of the surrounding starlight from stars. The end result is that the nebula really stands out a lot. And since emission nebula are all relatively near-by, Doppler shift isn't a big concern.
The bandwidth of the filter is particularly important for the starlight reason. If you have a very narrow narrowband filter (for example 3 or 7 nm bandwidth as opposed to 12 nm bandwidth), it will block out much more starlight from the surrounding stars compared to a narrowband with a larger bandwidth. As an example, take the veil nebula (google an image of it if you're not familiar). It has a lot of background stars around it -- so much so that an astrophotographer might say, "oh my, I wish I could dim the brightness of all those pesky stars, and let the beautiful nebula shine through." Well, narrowband filters with a small bandwidth can do just that. The smaller bandwidth of the filters, the more pronounced the nebula.
But there are a few big downsides to narrowband filters with a very narrow bandwidth.
  • Generally speaking, the smaller the bandwidth the higher the price.
  • Generally speaking, as the bandwidth gets smaller, some filters will have significant attenuation even in the center of the passband. That means you would have to increase your exposure time, even when photographing emission nebula.
  • When photographing broadband objects such as galaxies, very small bandwidth narrowband filters don't have any advantage at all over wider bandwith narrowband filters; and will require you to increase exposure time for no good reason. Both work equally well at blocking out light pollution.
On that last point: Narrowband filters are great at blocking out light pollution. And when it comes to emission nebula you don't even really need to change the exposure time much compared to a regular color filter. As long as the nebula's particular emission frequency is somewhere within the passband, that's about all that matters. That's not the same with galaxies though. The galaxy light that makes it through the filter is proportional to the filter's bandwidth. Narrowband filters block out light from the galaxy just like they block out light from stars.
If I had my choice and the resources (aka $), I would I would get a set of 7 nm or less narrowband filters for emission nebula (mapped to LRGB); but for galaxies a 12 nm Hα for the galaxies' luminance channel and use some other (non-narrowband) filters for the galaxies' color channels. (I live in a very light-polluted area.) Then again, maybe a "light pollution" filter might be better for galaxies, maybe. It wouldn't block out as much light pollution as a 12 nm Hα, but but the decreased exposure time might justify it. Then again, as long as I hypothetically have all the resources (aka $) anyway, I'd get both.
I am glad to hear that you are interested in using narrowband filters to improve your astrophotography and reduce the effects of light pollution. Red shift is a phenomenon that occurs when light from distant objects is stretched out, causing it to appear more red in color. This is due to the expansion of the universe, which causes the wavelengths of light to become longer as they travel through space.
In terms of using narrowband filters, red shift is not a major concern. The purpose of a narrowband filter is to block out specific wavelengths of light, allowing only a narrow range of wavelengths to pass through. This is useful for isolating specific emission lines from astronomical objects, such as hydrogen or oxygen. While red shift may cause the light from these objects to appear more red, it will not be enough to block them from passing through the filter.
However, it is important to note that the effectiveness of a narrowband filter may depend on the specific object you are trying to observe. For example, if you are trying to observe a galaxy that is very far away and has a high red shift, the filter may not be able to completely block out all the light pollution. In this case, using a filter with a narrower bandwidth may be more effective.
In summary, red shift should not significantly impact the use of narrowband filters for astrophotography. However, it is always important to consider the specific object you are observing and choose the appropriate filter to achieve the best results. I hope this helps and happy stargazing!
Related to Red shift and narrowband filters
What is red shift?
Red shift is a phenomenon in which light from an object appears to be shifted towards longer (redder) wavelengths. This is caused by the expansion of the universe, which stretches the wavelength of light as it travels through space.
How is red shift related to the Big Bang theory?
Red shift is a key piece of evidence for the Big Bang theory. The observed red shift in light from distant galaxies suggests that the universe is expanding, which supports the idea of a Big Bang event in which the universe began as a singularity and has been expanding ever since.
What are narrowband filters used for?
Narrowband filters are used in astronomy to filter out specific wavelengths of light from the night sky. This allows scientists to isolate and study specific objects or phenomena, such as distant galaxies or the emission lines of certain elements.
How do narrowband filters work?
Narrowband filters work by only allowing a very specific range of wavelengths to pass through, while blocking all other wavelengths of light. This is achieved through the use of specialized materials and coatings that are designed to selectively filter out certain wavelengths.
What is the difference between red shift and blue shift?
Red shift and blue shift are opposite effects caused by the Doppler effect. Red shift is observed when an object is moving away from the observer, causing its light to appear shifted towards longer (redder) wavelengths. Blue shift, on the other hand, is observed when an object is moving towards the observer, causing its light to appear shifted towards shorter (bluer) wavelengths.
  • Astronomy and Astrophysics
