Redox Titration Question - Answer Check & Questions
In summary: Ignore the reaction, it doesn't matter. All that matters is mass of the acid and its molar mass. Compare your question toA sample of hydrated ethanedioate crystals (formula H2C2O4 . 2H2O) was dissolved in water. Calculate the moles of ethanedioate ion present in the solution.In summary, 0.0017 mol of ethanedioate ion is present in the solution of the acid crystals.
reventon_703
Good day!
I would just like to confirm a couple things in regards to my solution for this problem.
Problem:
A sample of hydrated ethanedioic acid crystals (formula H2C2O4 . 2H2O) of mass 0.2145g was dissolved in water and the solution was used to standardise some potassium permanganate solution by titration in acidic conditions. 35mL of the KMnO4 solution were required to react completely with the ethanedioic acid solution. Calculate the moles of ethanedioate ion present in the solution of the acid crystals.
Background Information:
Oxidation of ethanedioate ions: C2O42- -> CO2
Reduction of permanganate in acid: MnO4- -> Mn2+
Solution:
First balance the equation.
6H+ + 5H2C2O4.2H2O + 2KMnO4 -> 10CO2 + 2Mn2+ + 2K+ 18H2O
(88.02g/mol C2O42-) / (126.08g/mol H2C2O4.2H2O) = (x) / (0.2145g H2C2O4.2H2O)
x = 0.149748493g 2O42-
Molar mass of 2O42- = 88.02g/mol
Mass of C2O42- = 0.149748493g
Number of Moles = 0.0017 mol C2O42-
Final answer: 0.0017 mol
Question
Is that the correct answer?
I was thinking if I need to multiply that 88.02g/mol and 126.08g/mol in that ratio by 5, because the balanced equation states there should be 5 moles of the hydrate used within that reaction. However, in this case it would not matter cause the two would cancel having been in both the numerator and the denominator. But technically, was the coefficient "5" needed in proper calculation? Or does it not matter?
Secondly, when I say H2C2O4 . 2H2O, there is 2 + 4 = 6 Hydrogen atoms, but when I put a coefficient in front of the hydrate, say 2, 2H2C2O4 . 2H2O, the 2 should apply to the whole hydrate including the H2O correct? So there should be 2(2) + 2(4) = 12 Hydrogen atoms, NOT 2(2) + 4 = 8. Can anyone please confirm this?
Your help is always appreciated, and I thank you in advance!
A sample of hydrated ethanedioic acid crystals (formula H2C2O4 . 2H2O) of mass 0.2145g was dissolved in water. Calculate the moles of ethanedioate ion present in the solution of the acid crystals.
Is it in any way different?
Related to Redox Titration Question - Answer Check & Questions
1. What is redox titration?
Redox titration is a laboratory technique used to determine the concentration of an unknown substance by measuring the amount of a reactant needed to completely oxidize or reduce it. It involves a redox reaction, which is a chemical reaction in which one substance is reduced (gains electrons) and another is oxidized (loses electrons).
2. What are some common examples of redox titration?
Some common examples of redox titration include the determination of vitamin C in fruit juices, the determination of iron in blood samples, and the determination of chlorine in pool water.
3. What is an indicator and how is it used in redox titration?
An indicator is a substance that changes color at a specific pH or in the presence of a certain chemical. In redox titration, an indicator is used to signal the end point of the titration, when the reactants have been completely consumed. This allows for the accurate determination of the unknown substance's concentration.
4. How do you calculate the concentration of the unknown substance in redox titration?
The concentration of the unknown substance can be calculated using the formula: CxVx = CsVs, where Cx is the unknown concentration, Vx is the volume of the unknown substance, Cs is the known concentration, and Vs is the volume of the known substance added.
5. What are some potential sources of error in redox titration?
Potential sources of error in redox titration include inaccurate measurements of volumes and concentrations, improper use of indicators, and incomplete reactions. It is important to carefully follow the experimental procedure and use precise measuring techniques to minimize these errors.
11K
16K
13K
15K
27K
