MHB Reduce an equation to a homogenous equation?
  • Thread starter Thread starter Cadbury
Cadbury
Hi, please help me solve this problem :)
Reduce (2x + 3y - 5) dx + (3x - y - 2) dy = 0 into a homogenous equation
I know that a differential equation Mdx + Ndy is homogeneous in x and y and if M and N are homogeneous functions of the same degree but given this, I have no idea where to start. Should I multiply both sides to something? Any help will be appreciated :)
Thank you so much!
Hi Cadbury,
I misunderstood your question at first but you can reduce your equation to a homogeneous type by a linear transformation of the form $u = x + A$, $v = y + B$ for constants $A$ and $B$.
Thank you so much!
Welcome on MHB Cadbury!...
... the procedure is tedious but not difficult!... setting $\displaystyle 2\ x + 3\ y - 5 = u$ and $\displaystyle 3\ x - y - 2 = v$ You obtain first...
$\displaystyle d u = 2\ d x + 3\ d y$
$\displaystyle d v = 3\ d x - d y\ (1)$
Solving (1) ...
$\displaystyle d x = \frac{d u + 3\ d v}{11}$
$\displaystyle d y = \frac{3\ d u - 2\ d v}{11}\ (2)$
... and now from (2) and the original equation...
$\displaystyle \frac{d y}{d x} = \frac{3\ du - 2\ d v}{d u + 3\ d v} = - \frac{u}{v}\ (3)$
... and finally with some steps...
$\displaystyle \frac{d u}{d v} = \frac{2\ v - 3\ u}{3\ v + u}\ (4)$
Kind regards
$\chi$ $\sigma$
Solving (1) ...
Kind regards
$\chi$ $\sigma$
Thank you very much! :) :) :)
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
