Reduced Density operator in matrix form
In summary, to calculate the reduced density operator using matrix notation, you can follow these steps: write out the density operator in matrix form, multiply it with the unitary transformation, sum over the elements corresponding to the second qubit, and calculate the von Neumann entropy to measure the entanglement.
munirah
31
I already read book of Quantum Computation and Quantum Information by Nielsen and Chuang according to reduced density operator and I already understand how to do the reduced density using Dirac notation, Ket Bra.
[/B]
My problem here I want to know the calculation/how to do reduced density operator if given In matrix form.
As example, given density operator in matrix,[in Dirac notation is represented by $\frac{|00\rangle+|11\rangle}{\sqrt{2}}\;$]
$$\rho =\frac{1}{2} \begin{pmatrix} 1 & 0 & 0 & 1 \\ 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \\ 1 & 0 & 0 & 1\end{pmatrix} $$
has been transform by local unitary, U as example
$$A=\begin{pmatrix} a & b & c & 1 \\ 0 & c & d & 0 \\ 0 & e & f & 0 \\ 1 & g & h & 1\end{pmatrix}.$$
After the transformation, I will get new density operator
$$\rho_\text{new}=\begin{pmatrix} a+1 & 0 & 0 & a+1 \\ 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \\ 2 & 0 & 0 & 2\end{pmatrix}.$$
[/B]
My problem here, I want to measure the entanglement. In Dirac notation, I already not to trace the second qubit if I want to find partial trace of first qubit. But how to know in matrix which one represent the 1st or second qubit and how to did the partial trace from given matrix.
Thank you
for sharing your understanding of reduced density operators and your attempt at solving this problem. To calculate the reduced density operator using matrix notation, you can follow these steps:
1. Write out the density operator $\rho$ in matrix form, as given in the question.
2. Write out the unitary transformation $U$ in matrix form, as given in the question.
3. Multiply the two matrices $\rho$ and $U$ together to get the new density operator $\rho_\text{new}$.
4. To find the partial trace of the first qubit, we need to sum over the elements of the matrix that correspond to the second qubit. In this case, the second qubit corresponds to the last two columns of the matrix. So, we can sum over the elements in these two columns to get the reduced density operator for the first qubit.
5. The elements in the first column of the reduced density operator correspond to the state $|0\rangle$, and the elements in the second column correspond to the state $|1\rangle$. So, the partial trace of the first qubit can be written as:
$$\rho_1 = \begin{pmatrix} a+1 & a+1 \\ 2 & 2\end{pmatrix}.$$
6. To measure the entanglement, you can calculate the von Neumann entropy of the reduced density operator $\rho_1$. This will give you a measure of the entanglement between the first and second qubits after the transformation.
I hope this helps! Let me know if you have any further questions.
FAQ: Reduced Density operator in matrix form
What is a Reduced Density Operator?
A Reduced Density Operator (RDO) is a mathematical representation of the quantum state of a system that is only concerned with a subset of particles or degrees of freedom. It is obtained by tracing out the degrees of freedom that are not of interest.
How is the Reduced Density Operator expressed in matrix form?
In matrix form, the Reduced Density Operator is represented by a square matrix with dimensions equal to the number of states in the subsystem. The elements of the matrix are obtained by taking the inner product of the full density operator with the basis states of the subsystem.
What is the significance of the diagonal elements of the Reduced Density Operator matrix?
The diagonal elements of the Reduced Density Operator matrix represent the probabilities of finding the subsystem in a particular state. These probabilities are obtained by taking the square of the absolute value of the corresponding element in the matrix.
How does the Reduced Density Operator relate to the full density operator?
The Reduced Density Operator is obtained from the full density operator by tracing out the degrees of freedom that are not of interest. This means that the Reduced Density Operator contains all the information about the subsystem that is relevant for calculations.
What are some applications of the Reduced Density Operator?
The Reduced Density Operator is widely used in quantum mechanics and quantum information theory. It is used for calculations involving mixed states, entanglement, and quantum correlations. It is also used in the study of quantum decoherence and open quantum systems.
