Reduced homology of sphere cross reals?
In summary, the conversation is discussing the calculation of the reduced homology of the product space S^n x R. It is mentioned that the n^th homology group is Z, but the question arises if the (n+1)th homology group should also be Z due to the dimension of S^n x R. However, it is clarified that in the case of closed manifolds, this is only true if the manifold is orientable. The conversation also discusses the homotopy of S^n x R, which deforms it onto S^n while keeping S^n fixed.
redbowlover
tex doesn't seem to be working right...sry for the notation.
Working through of a proof of the generalized jordan curve theorem. Keep getting stuck on calculating the reduced homology of S^n by R, (ie n-sphere cross the real line).
My book (hatcher) seems to imply its 0 except the n^th homology is Z.
But doesn't S^n cross R have dimension n+1? And shouldn't this imply the (n+1)th homology group is Z? Or is this only true of closed manifolds?
Any thoughts would be appreciated.
[tex]H_{n+1}(S^n\times\mathbb{R},\mathbb{Z}) = 0[/tex] because [tex]\mathbb{R}[/tex] is contractible.
the homotopy of S^n x R into itself defined by ((s,r),t) -> (s,rt) deforms S^n x R onto S^n
keeping S^n fixed.
Orientable and closed, in the manifold case.
It is possible that there may be an issue with the notation or calculations in your proof. However, it is also possible that the reduced homology of S^n cross R is indeed 0 for all dimensions except n, as suggested by Hatcher. This may be due to the fact that the n-sphere is contractible to a point, and therefore the cross product with the real line does not add any additional homology. This may only be true for closed manifolds, as you mentioned, since the open manifolds may have additional homology due to the boundary. It would be helpful to double check your calculations and potentially consult with other mathematicians or resources for further clarification.
Related to Reduced homology of sphere cross reals?
1. What is reduced homology?
Reduced homology is a mathematical concept used in algebraic topology to study the topological properties of spaces. It is a way of assigning algebraic structures to spaces in order to better understand their shape and structure.
2. How is reduced homology different from regular homology?
The main difference between reduced homology and regular homology is that reduced homology assigns a zero-dimensional structure to all spaces, while regular homology does not. This allows for more flexibility in calculations and simplifies the process of studying spaces with different dimensions.
3. What is the significance of studying the reduced homology of sphere cross reals?
The sphere cross reals is a well-known space in topology, and studying its reduced homology can provide insights into its topological properties. It can also be used as a model for other more complex spaces, making it a useful tool for understanding topological structures in general.
4. How are reduced homology calculations performed?
Reduced homology calculations involve breaking down a given space into smaller, simpler pieces. These pieces are then mapped onto an algebraic structure called a chain complex, which can be manipulated and analyzed using mathematical techniques to calculate the reduced homology of the original space.
5. Can reduced homology be used in other scientific fields?
Yes, reduced homology has applications in various fields such as biology, physics, and computer science. Its ability to capture topological features of spaces makes it a useful tool for analyzing complex systems and understanding their properties.
  • Differential Geometry
