- 893
- 483
I have a flat planar part made of crystalline sapphire (about ~2k weight, and polished to a mirror finish) that rests on three ball bearings, and I want to minimize the static friction at these 3 interfaces. The ball bearings are fixed so they cannot roll, and the sapphire part can only slip. (For the sapphire part, the c-axis is along gravity.) The one annoying constraint is that any materials used have to be ultra-high vacuum (UHV) compatible. For example, dry molybdenum disulfide powder is fine but anything containing oil is not fine (except for specialty UHV greases). Bonus points if the materials are also compatible with liquid helium temperatures (4K), but that's not a hard requirement for right now.
I can change the material of the ball bearings (I'm using teflon ball bearings right now), but I can't change the material of the sapphire part. The ball bearings cannot be smaller than 3/32in or bigger than 3/16in (I use 1/8in right now).
I tried coating the teflon balls with TaS2 powder (similar to MoS2 powder, but supposedly lower friction), but I don't feel any improvement sliding the sapphire part around. I also tried applying Apiezon L-grease (a UHV-compatible grease that is recommended for lubrication), and that made a slight improvement.
I believe the geometry the sphere/plane interface results in a lot of stress, and I fear that the lubricants are being "squished" out of the interface. I checked this by coating the ball bearings in grease and TaS2 powder, so they pick up a crusty layer of powder, and putting the sapphire part on top of them. When I did this, I saw that there was a tiny bald spot on the ball bearings where the sapphire part had been. I interpreted this as the weight of the sapphire part was "squishing" out the grease/powder mixture from the point of contact.
Any advice? Sorry, I know it's an oddball situation.
