Reducing Hip Fracture Risk with Elastic Hip Pads: What Acceleration is Needed?
In summary, falls resulting in hip fractures are a major concern for the elderly, with a typical impact speed of 2.0 m/s. However, wearing elastic hip pads can reduce the impact speed to 1.3 m/s or less, which usually prevents fractures. To achieve this, a typical pad that compresses by 2.0 cm during impact would require an acceleration of 1.3 m/s^2 to reduce the speed to 1.3 m/s. This can be calculated using the equation v^2 = v0^2 + 2a(x-x0).
maff is tuff
65
Falls resulting in hip fractures are a major cause of injury and even death to the elderly. Typically, the hip’s speed at impact is about 2.0 m/s. If this can be reduced to 1.3 m/s or less, the hip will usually not fracture. One way to do this is by wearing elastic hip pads.
If a typical pad is 5.0 cm thick and compresses by 2.0 cm during the impact of a fall, what acceleration (in m/s^2) does the hip undergo to reduce its speed to 1.3 m/s?
My attempt is attached below. Thanks everybody for the help :)
  • Fractured Hip.pdf
Does it compress to 2cm or by 2cm?
Oh it says by. So you're sayin my (x-x0) should be .02 not .03.
Correct :)
Yep that was the problem. Thanks man you've been helping me all day.
Related to Reducing Hip Fracture Risk with Elastic Hip Pads: What Acceleration is Needed?
1. How does decreasing speed affect an object's motion?
Decreasing speed slows down an object's motion. This means that the object will travel a shorter distance in the same amount of time compared to when it was moving at a faster speed. Additionally, decreasing speed can also affect the object's acceleration, causing it to decelerate or come to a stop.
2. What factors can cause a decrease in speed?
Several factors can cause a decrease in speed, including friction, air resistance, and the force of gravity. Other factors such as changes in surface or incline can also affect an object's speed.
3. How does decreasing speed impact an object's kinetic energy?
According to the law of conservation of energy, decreasing speed also decreases an object's kinetic energy. This is because kinetic energy is directly proportional to an object's mass and its velocity squared. As the object's velocity decreases, so does its kinetic energy.
4. Can an object maintain a constant speed while decreasing its speed?
No, an object cannot maintain a constant speed while decreasing its speed. In order for an object to decrease its speed, there must be an external force acting upon it. If the object were to maintain a constant speed, there would be no change in its velocity and therefore no decrease in speed.
5. How does decreasing speed affect an object's momentum?
Decreasing speed also decreases an object's momentum. Momentum is directly proportional to an object's mass and its velocity. As the object's velocity decreases, so does its momentum. This means that an object will be easier to stop or change its direction when its speed decreases.
15K
10K
