How Does Gear Count Affect the Efficiency and Size of Gearboxes?
In summary: Size and weight also depends very heavily on torque handling capacity, though of course that'll scale at least fairly similarly regardless of which gearbox design you chose.
Datt
I have a question what is a difference or advantage for using two gears with high gear ratio or using three gears with lower gear ratio.Is there any advantage.
Welcome to PF.
It depends on the overall ratio required. What ratio do you need?
The lightest weight and most economic gearbox will have pairs of gears, that each give a reduction ratio of about three. That comes about by considering the size and strength of the teeth.
If the ratio is greater than about 5.2 use more than one pair.
For one, adding an extra gear between two gears does not alter the gear ratio; It only changes the direction of rotation of the final gear.
To alter the final gear ratio, you need four gears, the middle two being on the same shaft. This adds extra friction losses and also extra inertia. Compared to a two-gear gear set, the final rotation is still reversed.
But the larger the gear ratio is, the more difficult it becomes to respect the combined design constraints like pressure angle, contact ratio, or undercut.
Likes Lnewqban
Baluncore said:
Welcome to PF.It depends on the overall ratio required. What ratio do you need?
That heavily depends on the gearbox.
For very high reduction ratios, planetary gearboxes can achieve much larger reductions than that in a single stage, which can end up more compact and lighter than a multistage conventional gearbox with a similar reduction ratio. Size and weight also depends very heavily on torque handling capacity, though of course that'll scale at least fairly similarly regardless of which gearbox design you chose.
There is no simple answer to your question. A complete answer depends on the ratio, power, speed, size constraints, efficiency constraints, cost constraints, and more. If you get a copy of Dudley's Handbook of Practical Gear Design, and read the entire book, you will be able to understand just how difficult it is to answer your question. The book is available from Amazon: https://www.amazon.com/dp/0367649020/?tag=pfamazon01-20. I read an earlier edition, and highly recommend it for completeness and readability.
Likes cjl
Planetary gears are used on coaxial shafts where side forces need to be minimised. The planetary reduction unit can still be smaller and lighter again when an axial stack of planetary gears is used, rather than only one high-ratio planetary stage.
FAQ: How Does Gear Count Affect the Efficiency and Size of Gearboxes?
How does the number of gears in a gearbox affect its efficiency?
The number of gears in a gearbox can significantly affect its efficiency. Generally, more gears allow for finer control over the output speed and torque, which can improve efficiency. However, each additional gear introduces more friction and potential energy loss, which can reduce overall efficiency if not properly managed.
Does increasing the gear count make a gearbox larger?
Increasing the gear count typically results in a larger gearbox because more gears require additional space. The design must accommodate the physical size of the gears and ensure proper alignment and spacing, which can lead to a bulkier and heavier gearbox.
What is the optimal gear count for balancing efficiency and size?
The optimal gear count depends on the specific application and requirements. For many applications, a balance is struck with a moderate number of gears that provide sufficient control over speed and torque without excessively increasing size and complexity. Engineers often use simulation and modeling to determine the best gear count for a given scenario.
How does gear count impact the maintenance of a gearbox?
A higher gear count can increase the complexity and frequency of maintenance required. More gears mean more components that can wear out or fail, necessitating more regular inspections and potential replacements. Simplifying the gear system can reduce maintenance needs but might sacrifice some efficiency or performance.
Are there any trade-offs to consider when choosing the gear count for a gearbox?
Yes, there are several trade-offs to consider. Increasing the gear count can improve control and efficiency but may also lead to a larger, heavier, and more complex gearbox. This can impact the overall system's weight, space requirements, and cost. Engineers must balance these factors to meet the specific needs of their application while minimizing drawbacks.
