Reducing surface integral to line integral?
In summary: The surface S is analogous to the point x=0 of the rod. If you adjust the equation to be in 1D, there is nothing to integrate--the function just takes on the value at the point x=0.
Guffie
23
hi I am trying to adjust this general integral to my problem,
my problem consists of a semi-infinite rod, i.e. x in [0,∞)
the primed variables are the integration variables
http://img339.imageshack.us/img339/5038/42247711.jpg
so since its a 1D problem it means that dS' = dx' right?
but the integral is a surface integral so its evaluated the the surface right? which is at x'=0
im a bit confused here, whether it should be (int dx' u(x',t') dG/dx'(x,t,x',t'), {x'=0...x})
or (int dx' u(0,t') dG/dx'(x,t,x',t')|x'=0, {x'=0...x}) (evaluated at the surface then integrated)
but if this is the case then youll just get x times u(0,t') dG/dx' at x'=0 which doesn't seem right..
would there even be an integral involved? would it just be
y(x,t) = int_{t,t_0} dt u(0,t') dG/dx'(x,t|x',t')|x'=0 ? < this seems like the correct way to do it to me.. I am just not sure the x' integral will go away..
which leads me to another point of confusion,
i know that dG/dn' = - something, but is it = -dG/dx' or = -dG/dx ?
im pretty sure its -dG/dx'
Where is S defined?
It might be necessary to modify it before you can reduce it to a 1-dimensional integral.
It would help if you were to state "your problem" as well as the source for your integral formula to judge whether and how it ought to be applied.
With that said I here will speculate on some points.
The dG/dn' would likely be the directional derivative of G in the direction normal to the surface. That would make it equivalent to the gradient of G dotted with the the unit surface normal.
[tex] \int dt' \iint y(r',t') \nabla' G(r,t;r',t') \bullet d\mathbf{S}[/tex]
You will likely have apply Gauss's Theorem (Divergence Theorem) to rewrite the surface integral as a volume integral. Then the integral over the rod will be nominally a volume integral with the cross sectional area component trivial. This though sounds like "undoing" whatever was used to derive the formula you stated. Again without context I'm speculating wildly.
But if I'm close then this formula is derived from some prior principle formula more applicable to your problem. It looks like a Green's function integral for some differential equation satisfied by y(r,t) but with additional application specific identities applied.
Even a subject context would help, is this a QM problem? An Electrodynamics problem? Gravitation? A pure math problem?
thanks for your replies!
ok sorry, i thought i could leave it general,
the formula i have given is the boundary value term of the general solution to the heat equation,
there a 3 terms, one associated with the driving function, one associated to initial conditions and one associated with boundary conditions.
in my question there is no driving function of initial conditions so only the boundary condition term is required.
the problem is one dimensional i.e. the differential equation is, k d^2u/dx^2 = du/dt, partials of course.
the boundary condition given is y(0,t)= A + Bsin(t)
the normal derivative to the greens function is negative because the rods 'surface' is at x=0 and opposing the direction of the rod, so in the -x direction.
its dG/dn' over the primed variables that's why i assumed it was -dG/dx'
i take it the surface S is supposed to be analogous to the point x=0 of the rod,
this is why I am getting confused,
if you have int f(r) dS' and the surface is defined to be a point in 1D, adjusting this to the 1D for, it wouldn't be an integral anymore? there's nothing to integrate? its just f(0) right?
thats what i am thinking is the correct thing to do but all the primed variables and stuff have made me pretty confused
OK, now we're getting somewhere. Yes your assumptions are correct.
The Divergence theorem reduces in 1 (spatial) dimension to the FTC. Remember the "outward normal" for an interval [a,b] on the x-axis then becomes [itex]-\hat{i}[/itex] at x=a, and [itex] \hat{i}[/itex] at x=b. And the gradient becomes simply [itex]\hat{i}\partial_x[/itex]. Presumably your x=b is at infinity and the functions are zero in that limit so there's no contribution. But I'll be more generic here but understand "evaluation at infinites" will be limits at infinity.
The "surface integral" for the zero dimensional "surface" of the 1-D "volume" becomes simple evaluation at that end point. So...
becomes...
[tex] \int dt' \left[ y(x',t') \partial/\partial x' G(x,t;x',t') \right]_{x=a}^{x=b}= \int dt' \left[y(b,t') \partial/\partial x' G(x,t;b,t') -y(a,t') \partial/\partial x' G(x,t;a,t')\right][/tex]
Remember the primed variables are the variables of integration, you are summing over one set of positions and times (r',t') via the integrals to find the values at another specific but unspecified position and time (r,t).
thanks alot!
Related to Reducing surface integral to line integral?
1. What is the difference between a surface integral and a line integral?
A surface integral is a mathematical tool used to calculate the net flow of a vector field across a two-dimensional surface, while a line integral is used to calculate the net flow of a vector field along a one-dimensional curve.
2. Why would someone want to reduce a surface integral to a line integral?
Reducing a surface integral to a line integral can make the calculation simpler and more manageable. It also allows for a better understanding of the behavior of a vector field along a specific curve.
3. How is a surface integral reduced to a line integral?
This reduction can be achieved using the Stokes' theorem, which states that the surface integral of a vector field over a closed surface can be expressed as the line integral of the same vector field along the boundary curve of the surface.
4. In what situations is reducing a surface integral to a line integral useful?
Reducing a surface integral to a line integral is often useful in physical and engineering applications, such as calculating the work done by a force along a specific path or determining the flux of a fluid through a given surface.
5. Are there any limitations to reducing a surface integral to a line integral?
While reducing a surface integral to a line integral can simplify the calculation, it may not always be possible. This method is only applicable to closed surfaces and cannot be used for open surfaces or surfaces with holes.
