Reduction in Heisenberg uncertainty
In summary, the theoretical experiment attempted to predict the location of a photon in one dimension based on its speed and time. However, there were many problems with the experiment that make it unreliable.
denni89627
71
I am writing this on the curiosity of the results of a theoretical experiment. Imagine a photon moving thorugh space. It is moving freely through three dimentions and time. Using the Lorentz contraction we can only know approximately where it will be in 3 dimentions for a given time and speed. Now imagine taking 2 panes of glass that are infinitely smooth, and sandwiching the photon between them. The panes are the exact width of the photon apart, so now the photon can only move in two dimentions and time. Let's take it one step further and bring two more sides in so the photon can now only move in one dimention and time. Imagine it's in a tube the
exact circumference of the photon itself. How would this photon move in one dimention? Could it's exact location for a given time and speed now be predicted?
There is a boatload of problems here in which you have to suspend other physics to sustain what you want to do:
1. What is the "size" of a photon? It's wavelength? Do you realize what would happen if you make light pass through a slit comparable to its wavelength?
2. Why would "infinitely smooth" glass matter? Just so it is 100% reflective? Not possible unless you want to change the mass of electrons to zero (which would change our universe completely).
Zz.
People have tried to make thought experiments like this before, by somehow constraining double slit experiments and thinsg of that nature. Wormholes, infinitely long strings, domain walls, Planck scale physics constraints (ad nauseum)
Something always goes wrong though, much like the old perpetual motion things. Often unitarity is violated somewhere microscopically, or the classical recipes violate some energy condition etc etc.
Related to Reduction in Heisenberg uncertainty
1. What is the Heisenberg uncertainty principle?
The Heisenberg uncertainty principle is a fundamental principle in quantum mechanics that states that there is a limit to the precision with which certain pairs of physical properties of a particle, such as position and momentum, can be known simultaneously.
2. How does the Heisenberg uncertainty principle relate to reduction in uncertainty?
The Heisenberg uncertainty principle states that the more precisely we know the position of a particle, the less precisely we can know its momentum, and vice versa. This means that any attempt to reduce uncertainty in one property will result in an increase in uncertainty in the other.
3. Why is the Heisenberg uncertainty principle important?
The Heisenberg uncertainty principle is important because it sets a fundamental limit on our ability to measure and understand certain physical properties of particles. It also has implications for the behavior of particles at the quantum level and is a key concept in quantum mechanics.
4. How does the reduction in uncertainty occur?
The reduction in uncertainty occurs through the process of measurement. When we measure one property of a particle, we collapse its wave function and gain information about that property. This results in a reduction of uncertainty in that property, but an increase in uncertainty in the complementary property.
5. Can the Heisenberg uncertainty principle be violated?
No, the Heisenberg uncertainty principle is a fundamental law of quantum mechanics and cannot be violated. It is a consequence of the wave-particle duality of matter and is supported by numerous experimental observations. However, it is possible to work around the uncertainty principle by using certain techniques and measurements.
