Reequilibriation of a System Disturbed from Stable Equilibria
In summary, the Earth's oceans are homogeneous mixtures with uniform total solute concentration, but individual components may have non-uniform concentrations due to local factors. The time for the depressed metal ion concentration to rise back up would depend on various parameters and can be described by Fick's 2nd law.
jay.yoon314
Hey.
Somewhat of a strange, but possibly profitable question!
I'm aware that a system that is at a stable equilibrium point will, upon a disturbance, return to that equilibrium.
Consider the Earth's oceans, which is essentially a multicomponent homogeneous mixture, or a multicomponent solution.
Question:
If you had a "metal-loving bacteria colony" densely concentrated in a small, say an imaginary spherical region 100 m undersea with a diameter of 1 cm or so that precipitates a specific metal ion out of solution at a fairly high rate (not sure what that would be), so that the bacteria are coated with solid metal, and these metal coated bacteria sink down because of their higher density, would the time that it took for the depressed metal ion concentration within that imaginary sphere to rise back up to about 99% of the initial concentration be, in your view, be so short that you couldn't really precipitate the metal fast enough even if you really tried (it re-equilibriates very quickly), so long that that spherical region would, even with complete ceasing of bacterial precipitation, remain depressed in its concentration (relative to the equilibrium concentration), or somewhere in between?
Are the Earth's oceans homogeneous mixtures/solutions in that the total/aggregate solute concentration is uniform throughout the volume of the ocean, or is it the "stronger" condition of each component, that is, each cation and anion being uniformly dissolved; i.e., so that the chloride and the sodium ions are both homogeneously dissolved?
If the answer to the first question is with a dissolved ion that is present at a very low equilibrium concentration, say that of strontium or gold ion, will the rate of replenishment and re-equilibriation of the imaginary spherical region be smaller in linear proportion to the ratio of the chloride ion equilibrium concentration to the gold ion equilibrium concentration?
What parameters does the diffusion rate through this imaginary sphere depend on? Would the relationship be given by Fick's 2nd law?
Thanks a lot!
The Earth's oceans are homogeneous mixtures in the sense that the total/aggregate solute concentration is uniform throughout the volume of the ocean. The individual concentrations of each component, such as chloride and sodium ions, may not be uniform due to local factors.If the metal-loving bacteria colony was densely concentrated in a small region, it is likely that the time for the depressed metal ion concentration within that imaginary sphere to rise back up to about 99% of the initial concentration would be relatively short. However, this would depend on various parameters such as the size of the region, the rate of precipitation, the diffusion rate through the region, and the equilibrium concentration of the metal ions in the surrounding water. The relationship between the diffusion rate and these parameters is given by Fick's 2nd law.
Related to Reequilibriation of a System Disturbed from Stable Equilibria
1. What is meant by "reequilibriation" of a system?
Reequilibriation refers to the process of a system returning to a state of equilibrium after being disturbed from its stable state.
2. What are some examples of systems that undergo reequilibriation?
Examples of systems that undergo reequilibriation include chemical reactions, biological systems, and physical systems such as pendulums or springs.
3. What factors can cause a system to be disturbed from its stable equilibrium?
Some factors that can cause a system to be disturbed from its stable equilibrium include changes in temperature, pressure, or chemical concentrations, external forces, or sudden disturbances in the system.
4. How does a system return to its stable equilibrium after being disturbed?
The exact process of reequilibriation depends on the specific system, but generally, the system will undergo a series of changes or reactions in order to reach a state of equilibrium. This can involve the release of energy, rearrangement of particles, or other processes.
5. Can a system be permanently disturbed from its stable equilibrium?
In some cases, a system may not be able to return to its stable equilibrium after being disturbed. This can happen if the system undergoes a drastic change or if the disturbance is too sudden and severe. However, in most cases, systems have mechanisms in place to bring them back to equilibrium over time.
  • Astronomy and Astrophysics
