Reference frame for analyzing ball rolling down incline
In summary, we are analyzing the problem of a ball rolling down an incline plane by calculating the KE as a function of velocity down the plane, and that is equal to the change in gravitational PE.
dsdsuster
30
Hi all,
I have a question about how to analyze the problem of a ball rolling down an incline plane. Assuming there is friction, at each instant the ball swivels about a pivot point on the incline that is stationary due to static friction. We then would analyze the torques about this point and find the rate of change of angular momentum.
However, at every instant, aren't we switching to a pivot point at a different location along the incline. Angular momentum is dependent on the choice of the coordinate origin and so is torque.
Am I understanding the way we are analyzing this problem correctly? or am I over complicating things?
So if we are analyzing the system each instant and at a different pivot point, and a different coordinate origin, how can we piece together all the information so the speak and describe how the ball is moving to a single stationary observer?
Problems like this are best solved through conservation of energy rather than through forces and torques. Don't worry about the forces or the pivot points, just calculate the KE as a function of velocity down the plane, and that is equal to the change in gravitational PE.
The thing is that we do the calculation at an arbitrary instant of time, within the time interval we are interested in. Since the result of the calculation is shown to hold true for an arbitrary instant of time within the interval, we can conclude that the result holds for all instants of time in question.
FAQ: Reference frame for analyzing ball rolling down incline
1. What is a reference frame in physics?
A reference frame in physics is a coordinate system used to describe the position, motion, and interactions of objects. It is usually defined by a set of axes and a point of origin, and can be either stationary or moving.
2. How does the choice of reference frame affect the analysis of a ball rolling down an incline?
The choice of reference frame can greatly affect the analysis of a ball rolling down an incline. In a stationary reference frame, the ball's motion will appear as a straight line due to the effects of gravity and friction. However, in a moving reference frame, the ball's motion will appear more complex due to the added velocity of the incline.
3. What is the most commonly used reference frame for analyzing a ball rolling down an incline?
The most commonly used reference frame for analyzing a ball rolling down an incline is an inertial reference frame. This is a reference frame that is not accelerating or rotating, and therefore follows the laws of Newtonian mechanics.
4. Can the reference frame affect the measurement of the ball's speed?
Yes, the reference frame can affect the measurement of the ball's speed. In a stationary reference frame, the speed of the ball will appear constant. However, in a moving reference frame, the ball's speed will vary due to the added velocity of the incline.
5. How can the reference frame be changed to simplify the analysis of a ball rolling down an incline?
The reference frame can be changed by choosing a frame that is moving with a constant velocity in the same direction as the incline. This will eliminate the added velocity of the incline and simplify the analysis of the ball's motion.
