Reference source of study for welding clamping force calculation
In summary, the document discusses the methodology and importance of calculating welding clamping force to ensure effective and precise welding operations. It outlines the factors influencing clamping force, such as material properties, joint design, and welding process parameters. The reference sources provided serve as essential guides for engineers and technicians to determine appropriate clamping forces to prevent distortion and ensure high-quality welds.
Nitheeswar
27
TL;DR Summary
I need to know reference source about clamping forces required to hold the welding components
What are the factors considered while calculating clamping force requirement ?
Clamping force for welding based on thickness - 48*s^3
s- thickness
what are other factors considered along with thickness and i need a detail source/reference books?
That is a huge question. There can be no one reference book.
Most clamping force will be very specific, and based on experience.
F = k * width * (thickness)^3 .
But that ignores the clamp position and distance between the clamps.
What material ?
What welding process ?
Clamping parts together, to eliminate air gap ?
Or clamping a part to a fixing table without distorting the table ?
Likes DeBangis21
Material is SS and process is MAG
We are clamping sheet to fixed table which has a resting base
Is this formula F=12*b*s^3 is valid for only thickness upto 6mm or more?
The force needed to bend the beam, to close air gaps, prior to welding, is a function of s^3, so it should work for any thickness, s. The parameter not specified are the number and position of clamps.
You may know what you mean by that, but there are too many possible interpretations for me to make any sensible comment. Maybe we could have a picture or detailed diagram.
What are you welding to what, with what type of joint?
Do you use a backing strip of brass or copper?
Manual or robot process?
We can consider one sheet rested on table and clamped from top
Another sheet rested on bottom plate and also clamped from side which has rest plates on opposite side of clamping
We can consider two plates as L shape of length 1.5 m
It's a manual process and it is a fillet weld
My motive is to not only for one case
We want to study about clamping forces required for different orientations, thickness,lengths,weld sizes,positions etc,.
Then you need to study the elasticity of engineering materials, and the deflection of materials subjected to loads.
You will then be able to calculate the force required to straighten a part, and hold it in that position, while it is being welded.
https://en.wikipedia.org/wiki/Elasticity_(physics)
https://en.wikipedia.org/wiki/Young's_modulus
https://en.wikipedia.org/wiki/Euler–Bernoulli_beam_theory
Another alternative is to hire a very experienced welder (a few decades worth of varied experience) and turn him loose on building the project. 😱
(or at least join the team)
ok. we are deciding clamping force based on the deflection using concepts of deflection of materials subjected to loads
how deflection is found ? what are inputs for finding deflection?
Look for problems of fit by using a feeler gauge, or look for light passing through a gap that is due to imperfect stock or preparation.
A competent welder will know what is required. They should work with a mechanical engineer, to design the jigs and fixtures needed for a routine assembly.
Allowance will need to be made for shrinkage of the weld. As a weld fillet cools, it will close the angle slightly. The support jig will need to allow for that deformation.
Take a look at:
Title: Jigs and Fixtures Design Manual
Author: Prakash Hiralal Joshi.
McGraw-Hill Professional Publishing (2002)
ISBN: 0071405569
See: Chapter 10. Welding and Assembly Fixtures.
Likes Lnewqban
Here my question is,
If we are welding without clamping, then this causes some b deflection
To avoid deflection we are clamping the parts
For clamping force calculation, we are using deflection as input
how we can find the deflection caused due to welding?
As explained above, there is no simple answer or general calculation for that heat induced deflection.
It is a case by case analysis, where the skill of the welder and the temperature used make a big difference.
Wherever steel gets red, but is restricted to expand, it will deform (or shrink).
It will then contract when cooled down, pulling the surrounded material with same force that it tried to pushed it away when hot (previously to becoming red and plastic).
If you have a production line, where similar parts are welded together, experimentation with jigs and welding techniques (pre-spot welds along the joints, low temperature, etc.) will reveal the sweet spot to you quicker than inaccurate calculations.
Please, see:
https://www.engineeringtoolbox.com/stress-restricting-thermal-expansion-d_1756.html
https://www.engineeringtoolbox.com/linear-thermal-expansion-d_1379.html
:cool:
Likes berkeman
FAQ: Reference source of study for welding clamping force calculation
What is the importance of calculating clamping force in welding?
Calculating clamping force in welding is crucial because it ensures that the workpieces are held securely in place during the welding process. Proper clamping prevents distortion, misalignment, and defects in the weld joint, which can compromise the integrity and strength of the final product.
What reference sources are commonly used for clamping force calculations?
Common reference sources for clamping force calculations include welding handbooks, engineering textbooks, and standards published by organizations such as the American Welding Society (AWS) and the International Organization for Standardization (ISO). These resources provide guidelines, formulas, and case studies relevant to clamping force in various welding applications.
What factors influence the required clamping force in welding?
Several factors influence the required clamping force in welding, including the type of material being welded, the thickness of the workpieces, the welding process being used, and the design of the joint. Additionally, environmental conditions such as temperature and humidity can also affect the necessary clamping force.
How do you calculate the clamping force needed for a specific welding project?
To calculate the clamping force needed for a specific welding project, one must consider the material properties, joint design, and welding process. The calculation typically involves determining the required pressure to hold the workpieces together, factoring in the coefficient of friction, and applying relevant formulas that relate to the specific welding technique being used.
Are there any software tools available for clamping force calculation in welding?
Yes, there are several software tools available that assist in clamping force calculations for welding. These tools often include features for simulating welding processes, analyzing stress distributions, and optimizing clamping designs. Some popular software options include ANSYS, SolidWorks, and specialized welding simulation software.
